Xr4i wiper motor ground
Hello,
I have problems with the wiper motor it has no earth.
the ford workshop manual says the ground is next to the wiper motor. But when i follow the cable it goes in to the main cable bumdle.
anybody knows were i can find the ground?
is the wiper motor working if so its grounded. if its not working put your own ground on it any decent wire to the caseing or under a mounting bolt to the body work
According to the wiring diagram it is at the Headlight mounting panel - LH for LHD and RH for RHD. I think from memory, this earth is under the headlight screwed into the steel.
Cheers David
Cheers David
DUDE_SWEET_FRST
07-06-2007 08:18 PM
TheBishMan
19-01-2005 10:25 PM
