Zetec silvertop oil pressure
Old 01-05-2020 | 11:08 AM
Shortjedi's Avatar
Shortjedi
Default Zetec silvertop oil pressure
I have a 1.8 silvertop in my Lotus Europa. The oil pressure drops off when hot.
Smiths electric gauge, swapped sender still same. Pressure switch is a 20psi job and light is flickering.
The engine was a Ford short motor, crank has been ground 0.25mm u/s. Had it stripped and measured, all good. Oil pump and bearings look fine.
what is a normal hot pressure for these? Am I chasing shadows?
cheers
Old 01-05-2020 | 11:55 AM
haz87's Avatar
haz87
Hot pressures generally vary between 1.3-2.5bar at idle (18.8-36.2psi)
So if its just under 20PSI thats fine, but just relying on the low pressure switch/light is guesswork really. Whack a gauge on and get a proper idea of the pressure. Could be 5psi for all you know..
Old 01-05-2020 | 12:03 PM
Shortjedi's Avatar
Shortjedi
Thanks for the reply, that's lower than I expected on a "modern" engine. I could well be chasing shadows.
I've rigged up a mechanical gauge so I can cross check the electric gauge when it's all back together. If that's good I'll look into an adjustable pressure switch for the light.
the pressure rises nicely with revs.
Old 01-05-2020 | 12:09 PM
haz87's Avatar
haz87
The "newest" silvertop is 98 i think? Thats still 22years old - they aren't modern anymore
Old 01-05-2020 | 12:12 PM
Shortjedi's Avatar
Shortjedi
Haha, quite agree, modern compared to the tech I grew up with.
Essex, Cologne, Kent, Pinto, etc.
Old 01-05-2020 | 12:14 PM
haz87's Avatar
haz87
Yer don't worry, I'm of the same mindset until i actually stop and think how old some of the stuff i still mess with is
Shortjedi (01-05-2020)
Layland
25-07-2014 06:25 PM
ybp 096
Ford Escort RS Cosworth
12-01-2011 07:32 PM
smartrs
07-12-2009 11:03 AM
pani_k
46
16-08-2008 04:13 AM
scruffythefirst
11
19-04-2006 05:51 PM
