oil pressure
oil pressure
what should my oil pressure be at tick over ? the enginehas just had a full re-build using a new high pressure pump and was just wondering what the pressure should be at idle ?
hot less than 20psi is not uncommon
mainly to do with crank tollarance if its low it usually means you have a good coat of oil on the crank if its very high it could mean its tight and may pick up
so low oil pressure is not always bad
exactly,,, and further more as long as the pressure increases when the engine is revved then happy days.
i'm not seeing nothing like that on tick over i get about 2 bar if i bring the revs upto about 2000rpm it on some shitty oil for the running in period if that makes and differance but the gadge reads almost nothing in pressure on first start up it was around 3.5 bar but i dont see nothing like that now , i'm just wondering if the gadge is faulty
IF your running in you could have some swarf in the relief valve, or the oil could have become contaminated from running in.. How many miles you done on it??
What is your idle speed, and from cold what does the pressure show?
If it's not the gauge then there MUST be a problem internally m8! as even a standard pump will give you roughly 25 psi on tick over and your running a high pump!
its only just been run on the drive i've had the diff and brakes to d on it too so its not been on the road so 0 miles i see about 2 bar on start up but that drops down after that . i cant see how any swarf can be in there every thing was cleaned checked cleaned again i put together with no way any thing could of got in there . i removed the oil filler cap while it was running and i can see oil being thrown around
A mate of mine had a brand new fucked pump on his old saph, cost him an engine
With the turbo oil return undone, there was a good stream of oil coming out the pipe when the engine was being turned over on the starter, with the fucked pump in it was barely a run, more of a drip!
Trust me mate I have been there exactly the same problem as you,
Fully rebuilt engine lost pressure all of a sudden,
First time started ever it was 65 psi on cold. After running it in 800 miles later the pressure dropped to 15. From then it would be 30 at cold first startup then stay at 15/20and max pressure was 40 at 5k rpm.
Took of sump and the bearigns were fucked and swarf everywehere,
The cause was a dodgey new oil pump for me. But you could have a sticky relief valve + How did you prime the engine when first starting it ??
i really hope i dont have to pull the engine apart again i think my missus would actually kill me if i have to spend mush more on it before it gets back on the road
just do an independent check with another oil pressure gauge,take it from the oil feed to the turbo..if thats the same its engine out and sump of..hopefully youve done no damage to the crank/shells etc
cheers danny
cheers danny
i tried connecting my other gadge to the turbo oil feed but it does not seal quite correctly so i could not get a reading from that but i do now know there is a steady flow at the oil feed pipe . ive also noticed the gadges do funny things when other electrical stuff is turned on and am thinking maybe there not getting a good ground which is causing the dodgy readings and my panicing
but the engine in mine was perfect; i connected up another mechanical gauge and the pressure was ideal - panic over
i had some really shitty gauges in my 2wd cossie; the oil pressure was really low which worried me - if i turned all the electrics on the gauge would read zero oil pressure!!!
it wasnt helped because of the sender was a different make to the gauge itself, all senders differ in resistance which again will give an inaccurate reading.
if you have zero oil pressure, the motor will probably knock it tits off at idle, if the gauge does raise with revs then i dont think you have anything to worry about.
