FRST RUNNING PROBLEMS, HELP!!!!!
Old May 17, 2004 | 10:05 AM
IANS2RST's Avatar
IANS2RST
Default FRST RUNNING PROBLEMS, HELP!!!!!
I have a frst which will does not drive smoothly on part throttle.
if you drive below 50/60 mph it will stay off boost and perfectly smooth, up to 90 it will not drive smoothly. I went to stamford hall yesterday and cruising in the convey it was constantly showing boost of 3-4 psi and juddering. when it went above 90 it was fine. Managed only 150 to a full tank of petrol
spec is 2.0l zvh, kent cam, t3, stage 1 chip, 10 psi boost. any ideas welcome
Old May 19, 2004 | 08:58 PM
Lee @ Fusion's Avatar
Lee @ Fusion
over fueling mate , till it clears i guess .
ive got the same probs with my 2.1
yours drives mine doesnt , get it to a garage and see if the co is set correctly , 3.5 % at idle
also check out the fuel pressure 3.5 bar but cant rember if thats with the vacume hose on or off ???
last thing it may be is the fuel pump , or wiring breaking down but that doesnt tally up with the poor fuel consumption .
bigryrs
Fiesta RS1800/RS Turbo
Sep 5, 2015 02:57 PM
bigryrs
Aug 28, 2015 05:32 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Zoggon
Aug 10, 2015 10:39 AM
