Rs1800 problems
Old Aug 9, 2016 | 05:18 PM
Fordmad!'s Avatar
Fordmad!
Default Rs1800 problems
Right, been putting car back together last 2 days. Started playing up at the bodyshop which i thought was the battery but now realise its not. Worked out that its the ford deadlock (or whatever you call it) It kicks in when it wants. Sometimes it starts sometimes it dosent. If you unlock then lock and hold key for 2 seconds then unlock the door it usually starts. How do i get it to stop doing this?
Someone has said it could be something in the locks that has worn that causes deadlock to kick in and out.
Also the windows, electric mirrors or boot release don't work either which i take it must be all connected.
Really annoying as anther days work and it'll be ready for mot
Any help would be MUCH APPRECIATED!
Old Aug 9, 2016 | 05:55 PM
NobbyClark's Avatar
NobbyClark
I wish I could help matey but alas!!
My problem is with my mk5 Escort saloon and the fact that I cannot get into it!! Neither key will open either of the front doors!!
I hope you get someone has a suggestion for you and it gets sorted!!
Old Aug 9, 2016 | 08:30 PM
Fordmad!'s Avatar
Fordmad!
No worries! Can you open the bonnet? Did this to a megane not long back it locked itself with keys in so i sparked the battery and the doors unlocked
Old Aug 9, 2016 | 10:14 PM
NobbyClark's Avatar
NobbyClark
Cannot get the bonnet open matey!!
Old Sep 12, 2016 | 07:46 PM
Fordmad!'s Avatar
Fordmad!
Can anyone help? Put new starter motor on and not cured problem. Doesn't start at all, dash lights come on, pump primes but nothing when key is turned
Old Sep 15, 2016 | 06:26 AM
mattxr3i's Avatar
mattxr3i
Do these suffer fusebox issues like the Escort? Have you checked the main fuses as it sounds like it could have popped. Checked your earths around the engine bay? Also, on the Escort which maybe the same as the fiesta, there is a small wire for the immoboliser that gets mossed sometimes
Old Sep 16, 2016 | 06:37 AM
Fordmad!'s Avatar
Fordmad!
Had someone look at it yesterday. Seems theres an immobiliser issue cutting the crank to the starter. He routed out the wire in the fusebox and cut it. Now with an earth to it the car starts. My clock doesn't work so can't see what flashing code the immobiliser is throwing up. Also I've just put a new starter on and that now runs constantly. Until he gets a wiring diagram he can't do anymore.
Really thinking i need the standard immobiliser taking off. Also only have the master key so need another one cutting. Such a headache!!!!!!
dissmalrs
Mar 20, 2016 01:42 PM
j@mie
Mar 19, 2016 07:08 PM
beller
Mar 1, 2016 04:47 PM
3door
Dec 11, 2003 04:26 PM
Milko
Ford Escort RS Cosworth
Nov 24, 2003 02:35 PM
