fireproof tape
Old Aug 3, 2016 | 03:30 PM
mad max's Avatar
mad max
Default fireproof tape
Hi ,can anyone recommend a good fireproof tape as i need to wrap a connection that is near the turbo /and exhaust manifold ,looks like the connecting plug for the twin fans (cooling) as i can see that at some point it as got a bit hot and tried to melt ,previous owner not me lol thanks
Old Aug 3, 2016 | 03:37 PM
Caddyshack's Avatar
Caddyshack
10 Year Member
I think that fireproof tape will just stop the tape catching fire but would not protect the plug from the heat. Go to Demon Tweeks or Motorsport tools site and look at heat reflective products and wrap it in that. Also try and move - re route - re wire the plug away if possible, surely just needs a small extension?
You could consider heat wrapping the manifold or better still Zircotec coating (pricey)
Old Aug 3, 2016 | 09:16 PM
slammedorion's Avatar
slammedorion
I've just done a fair bit of heat protecting under the bonnet as I've just changed my exhaust manifold
Heat wrapped the manifold
Heat protective matting on underside of bonnet
https://www.ebay.co.uk/itm/151890400023
Heat protective sleeving
https://www.ebay.co.uk/itm/302012118280
Still need to reroute the bonnet release cable, but for now it's wrapped with the sleeving stuff
Old Aug 4, 2016 | 07:02 AM
visa_broke's Avatar
visa_broke
10 Year Member
slammed orion - that looks really good, really well done!
Old Aug 4, 2016 | 09:17 AM
slammedorion
Hope it all does its job for now
Old Aug 4, 2016 | 08:42 PM
dojj's Avatar
dojj
Resident Wrestling Legend
the heat proof wrap is the best thing to be honest, it will reflect the heat away from what needs to be protected and as it's a slide on thing you can simply remove it if it's going to be moved out of harms way later
i might have had 3 layers on my clutch cable...
johnboy73
Apr 8, 2016 08:36 AM
Windle
Dec 18, 2003 10:51 PM
B11GNS
Oct 31, 2003 03:08 PM
B11GNS
Oct 28, 2003 12:13 PM
rizla
Sep 30, 2003 04:42 PM
