YB cam seal still leaking HELP?
Old Jun 18, 2016 | 10:50 AM
peter2wdsaff's Avatar
peter2wdsaff
Default YB cam seal still leaking HELP?
Hi and thanks for looking
i have a 2wd saf running stage 3 with armed chip etc and i cant get the cam seals to stop leaking
replaced the seal (with VITTON once) twice and all the o rings etc
all the caps are tightened to the right settings
the leak seems to be more on the right side cam and less on the left and it leaks more if ive driven the car hard?
i also get a little white / blue smoke from the exhaust after a hard run and come off over run say slowing down form +70mph after a fast bit ? not sure if its related
I've checked the breather system (kidney box) also it have a bailey breather system with a pip off the cam cover cut out an the back also
other than that the car runs and drive great no smoke on start up and normal driving , only off over run when had a high boost
any help or ideas what to check and help with diagnosis that would be great
Old Jun 21, 2016 | 06:07 PM
cossie2's Avatar
cossie2
..change cam bearing spacer..it is probably worn..
Old Jun 21, 2016 | 06:35 PM
155lee's Avatar
155lee
No sealant between the cam cap and head.
Old Jun 22, 2016 | 10:35 AM
peter2wdsaff
replaced them to
Old Jun 22, 2016 | 10:36 AM
peter2wdsaff
yep def sealant used two types as was leaking after the first time so thought the same
Old Jun 22, 2016 | 11:52 AM
Loomer's Avatar
Loomer
check the cams dont have a bend in them, maybe the nose is not sealing correctly against the seal.
Old Jun 22, 2016 | 02:24 PM
peter2wdsaff
will do next time its apart cheers
Old Jun 22, 2016 | 03:34 PM
Cossie92's Avatar
Cossie92
Cossie newbie
10 Year Member
Do you have sealant over and around the half moon seals as they usually leak? If it's indeed leaking from the cam seals and you have replaced them there is one thing to try aswell. There is a circlip over the cam bearings which has ~5 mm opening on it and it sits in a groove. I rotated the circlip so that the opening is upwards, instead of any other way. Don't know if it makes difference but I did this.
Old Jun 22, 2016 | 04:53 PM
peter2wdsaff
yeah will try that cheers
ill look at adding more sealant to the half moons too
Old Jun 23, 2016 | 06:52 PM
YBJ's Avatar
YBJ
Thinking Cosworth..
Use a blob of Loctite 5910 at the ends of the half moons where they touch the head. That will do the trick.
Old Jun 24, 2016 | 07:29 AM
peter2wdsaff
cheers did that still no luck
Old Jun 1, 2019 | 11:36 AM
d-a-n's Avatar
d-a-n
I know this an old post but did you ever sort it. Im struggling with mine.
admanrs
Aug 29, 2016 05:02 AM
Ellsa
Apr 1, 2016 03:22 PM
cozzy jeff
Mar 31, 2016 03:44 PM
fuzzy
Mar 23, 2016 04:36 PM
jdsjojo
11
Mar 22, 2016 08:11 PM
