2011 transit duratorq starting
Old Jun 3, 2016 | 03:58 PM
pig's Avatar
pig
Default 2011 transit duratorq starting
wondered if anyone can shed some light on this please.tun the key and it appears to want to start but wont.seemed worse when cold,ive fitted a genuine ford fuel filter and housing as i know they can be trouble but still the same fault.replaced the pipes from tank etc and pump to housing pipe also air filter.it will start ad run striaght away if i poke some clutch and brake cleaner up it.i tryed to get a fuel pressure sensor on the fuel rail but they only come with fuel rail attached (320).my code reader is showing no stored or current faults either.any help welcomed,cheers paul
Brickhouse
Ford Mondeo Including ST
Jul 20, 2016 11:18 PM
purpleka
Ford KA
Mar 19, 2016 07:46 PM
j@mie
Mar 19, 2016 07:08 PM
Danielbetty
Mar 14, 2016 10:55 AM
Brickhouse
Mar 6, 2016 02:29 PM
