Fault codes, please help. Mondeo.
Old Mar 6, 2016 | 11:46 AM
Brickhouse's Avatar
Brickhouse
Default Fault codes, please help. Mondeo.
I have a 2003 Mondeo 2.5 V6 so the pre-facelift version. I recently put some facelift (2005) seats/carpet/doorcards etc in as I liked the look due to being half leather and black as mine was all cream leather. Since putting the facelift interior in my airbag light flashes 5 times then stops, then once, then stops then five times then once.....I found out this is called 'Error 51' so found on Ford Wiki this.......
DTC B2691: Driver safety belt buckle switch open circuit or short to battery. Lamp flash code: 51
Possible Source(s):
Driver safety belt buckle switch.
Circuit(s).
DTC B2435: Driver safety belt buckle switch resistance out of range. Lamp flash code: 51
Possible Source(s):
Circuit(s).
I have looked everywhere on the drivers seat to the sides, underneath etc and cant find any 'Drivers safety belt buckle switch' Can anyone help please?
Thanks in advance.
Old Mar 6, 2016 | 02:29 PM
mark826's Avatar
mark826
The switch would be internal of the drivers seat buckle. I'd check the wire coming from the buckle isn't broken and that it is connected to the main loom
fakejimmymorgan
Ford Focus ST
Apr 6, 2016 01:12 AM
41
Feb 19, 2016 09:15 PM
Rob33
Feb 12, 2016 06:46 PM
neil.j
Feb 10, 2016 10:25 AM
paceo
Feb 8, 2016 08:02 PM
