rs turbo efi conversion
Old Mar 6, 2016 | 04:18 PM
akydawn's Avatar
akydawn
Default rs turbo efi conversion
hi every one i have just restored my rs turbo and i did a efi conversion on it i have used a late rs turbo block that has the crank sensor hole and used a efi head ,efi full wiring loom and a ofab ecu and i cant get a spark i have tried changing the crank sensor as i have a escort efi cab so i have swapped it with that no luck a have swapped the edis 4 i have swapped the coil pack ihave got 12v at the coil i have power to the ecu and power to the edis i have checked the earths and still nothing the fuel pump primes i have tried almost every thing some please help
jacobwigley
Jan 31, 2016 07:12 PM
Pitbull69
Jan 9, 2016 04:50 PM
jorgeforcinas
Jan 8, 2016 08:20 AM
Ellsa
Jan 5, 2016 02:17 PM
Fused7
Jan 4, 2016 04:03 PM
