Piecing back an Rs Turbo engine - advice?
Old Apr 18, 2016 | 10:20 PM
simonmcf's Avatar
simonmcf
Default Piecing back an Rs Turbo engine - advice?
After a good years I'm finally starting to see some light at the end of the tunnel on my escort rs turbo build. I bought an engine, loom and box running efi to make life a little easier. It's running an aftermarket cam and I can't see that some porting/polishing was done. Anyway last weekend I repainted the block and gearbox and can know think about bolting stuff back on. I wanted to check if there any must do jobs before the engine is dropped back in. I plan to do the following:
1) new sump, plug and gasket
2) new exhaust manifold gasket and manifold to turbo gasket
3) new inlet manifold gasket
4) new thermo (and gasket?)
5) swapped old starter for a newer ford tcdi one
6) new t belt, tensioner and water pump
7) new oil pump and oil filter
8) new rocker cover gasket
I also have head gasket, stretch bolts, but not sure if fit these now? Should I replace the crusty studs and nuts for inlet/exhaust manifold? Anything else I should consider?
Simon
Old Apr 19, 2016 | 05:02 AM
haz87's Avatar
haz87
If you're going to swap out the inlet/ex studs, do it now with the engine out because if they pull the threads its sooo much easier fixing it with the engine out.
Id personally swap the HG/headbolts not knowing its history. Also gives you a chance to check the piston tops/chamber condition
Old Apr 30, 2016 | 09:43 AM
Turbomike89's Avatar
Turbomike89
Simon
Be weary for new sumps from the Far East- can be tricky to fit without leaks at the best of times oh and I'd definitely be having head off and plastigauging the journals while sumps off
Chris 82
21
Sep 21, 2019 06:02 PM
MADMAXPTT
Mar 7, 2016 09:49 PM
anth77
Mar 5, 2016 07:58 AM
Mk4 Rick
Mar 3, 2016 07:47 PM
JPA
Feb 25, 2016 08:35 AM
