Another Cosworth misfire problem!!
Old May 16, 2004 | 02:56 PM
Diablo's Avatar
Diablo
Default Another Cosworth misfire problem!!
My Escort Cosworth is either misfiring, overfuelling or a combination of the two. It is getting an even spark to all cylinders, but runs very lumpily and fouls the plugs very quickly.
What would be the symptoms if the phase sensor and speed sensor were not working?
Also, if the coolant temperature sensor had gone, would it cause the car to overfuel from cold?
Any help would be greatly appreciated.
Old May 28, 2004 | 01:28 PM
rs nuts's Avatar
rs nuts
if it was the water temp sensor the injectors whould not fire evenly and whould not run about the other 2 i cant help
Old May 28, 2004 | 09:57 PM
DazC's Avatar
DazC
Coolant temp sensor would cause it to over fuel...
The phase and crank sensor would cause it to cut out, struggle to start or run for a brief moment then die...
Old May 29, 2004 | 04:07 PM
dave cos4x4's Avatar
dave cos4x4
Map sensor would cause it to over fuel too.
Better getting a pectel monitor on it,this reads all the sensors and it wil tell you which ones faulty.
Dave.
j.hammond1
30
Oct 31, 2021 05:28 PM
Topjoe9
Aug 20, 2015 02:38 PM
Aug 14, 2015 07:29 AM
taylora1409
Aug 12, 2015 12:06 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
