Focus St 225 ESP SYSTEM FAULT
Old Mar 4, 2016 | 12:39 PM
JordanSpencer's Avatar
JordanSpencer
Default Focus St 225 ESP SYSTEM FAULT
Hi all,
My Ford Focus ST 225 2006 has a very annoying issue;
When I select 6th gear and am doing say 30mph, if I put my foot flat to the floor, (Still in 6th) I get an ESP System Fault, and loose the majority of the cars power as the turbo switches off. I have replaced the Fuel Rail Pressure Sensor but am still having the exact same issue. Does anyone have any suggestions? Or know what the actual issue is, I'd appreciate all suggestions and help.
Thanks for your time.
Jordan
Old Mar 4, 2016 | 01:08 PM
jam53ice's Avatar
jam53ice
Could be the MAF sensor, but to be honest, your best of plugging it into a diagnostic machine to see if any codes come up.
Old Mar 26, 2016 | 10:53 PM
Mick.M's Avatar
Mick.M
Originally Posted by JordanSpencer
Hi all,
Jordan
Don't know if pulling the kam fuse would help the problem.
Old Mar 27, 2016 | 12:56 AM
JordanSpencer
Hi,
Many thanks for your responses.
The issue was diagnosed today with three causes.
1) there were two leaks in the air flow pipes
2) the car needed re-balancing...
3) the pedal box was faulty!
Old Mar 27, 2016 | 06:55 AM
Mick.M's Avatar
Mick.M
Hi,
I would put it down to the leak on a pipe Jordan. Might even be a loose boost solenoid pipe. Glad your getting it sorted, keep me updated as i have an st 2 and more info the better.
melpear
Ford Focus Range
Sep 8, 2017 04:18 PM
arran15
Jan 13, 2016 05:42 PM
nickscunny
18
Jan 11, 2016 11:17 AM
Fordmad!
Jan 8, 2016 05:48 PM
FlashLam123
Ford Focus Diesel
Dec 29, 2015 02:07 PM
