Engine Spec...
Old May 13, 2004 | 07:46 PM
Dead and Gone's Avatar
Dead and Gone
Default Engine Spec...
I asked this in General Discussion but probably best in here
I'm planning on having my 4x4 Saphire Cossie engine rebuilt, what parts do you guys think should be used to get about 350 - 380bhp out of it? I've got a standard turbo on the car so might get a T4 or at least a Hybrid, I've got about 6 -7k to spend on it...
The reason I ask is I'm going to be taking my car to Cheshire Prestige & Performance over the weekend for them to have a look and give me a quote so I would like to make some surgestions as what to go for...
any help will be most welcome
Old May 13, 2004 | 08:10 PM
swerv's Avatar
swerv
6-7k will get you a good 400 conversion
BUT
if i had 6-7k to spend i would save 3k and spend that on brakes/suspension/diff , then spend 4k having a 360hp engine built.
if you go for something along the lines of T34/ .63 , BD14 inlet , light lues , WRC gasket youll have a some fun rather then getting the engine and not doing brakes and suspension then struggling to keep it on the road
HTH
Old May 14, 2004 | 03:09 PM
Andymancos's Avatar
Andymancos
if you want to save some cash on your engine build my mate john is EX-Turbosystems mechanic he would build you your engine to what u want no-probs
Old May 14, 2004 | 08:57 PM
Dead and Gone
BUT
HTH
Good idea sir, I have a very nice break setup but you are right I should get an engine running 360 and spend the rest on suspention and diffs...
Old May 14, 2004 | 08:59 PM
Dead and Gone
where abouts is he based? if he's not local would be difficult to get the car to him...?
Old May 14, 2004 | 11:19 PM
DazC's Avatar
DazC
A standard or near standard rebuild will be enough for 350-380 bhp.
Old May 14, 2004 | 11:54 PM
Andymancos's Avatar
Andymancos
He is in staffordshire mate if your intrested i can have a word with him for ya he worked at TURBOSYSTEMS from day one and 12 years later left to do his own stuff
Old May 15, 2004 | 10:08 PM
Dead and Gone
I know but I'd sooner have an engine that can do 400bph and back it off to say 350 - 380 so the strain on the engine is not so grate but I have the potential to do big bhp is I need too, or does not not make sence
Old May 16, 2004 | 09:17 AM
dave cos4x4's Avatar
dave cos4x4
you will need to have a good gearbox in it then to go over 380 etc.....
Where you from mate.
Do you know John from J.C Motorsport, he can sort all this for you.
Dave.
Old May 16, 2004 | 05:39 PM
DazC's Avatar
DazC
Depends on how you want the car to drive.
A standard bottom end can produce 400 bhp.....
You're best bet is to drop it to 7.7/1 compression ratio and either port the head or fit cams and then there is the reliability factor you need to build into it. Best to discuss it all with the engine builder to be honest.
Old May 16, 2004 | 08:13 PM
Dead and Gone
Dave.
I've seen the cars that he has worked on , i'm taking it to an place that was recommended before..
as for the gearbox, I should have a couple k left so will proably see how it goes
hopper350
Sep 4, 2015 12:53 AM
Sep 3, 2015 10:49 AM
