si problem
Old Mar 30, 2005 | 01:19 PM
BUNJY's Avatar
BUNJY
Default si problem
my mates got an m-reg si 1.4 and hes having a problem with his clutch. when he dips it, sometimes it just makes a loud click and while it still engages the clutch, gear change is a bit crunchier than it ought to be. has anyone ever come across this before? really dont have a clue cos its not all the time either, it just seems fine one minute, and sh*te the next. any help greatly appreciated lads.
Old Mar 30, 2005 | 01:53 PM
Owain's Avatar
Owain
His clutch pedal ratchet is shagged. Its what takes up cable slack, its a bugger to change but not expensive. He really wants to get it done asap before it completely goes and his clutch pedal goes straight to the floor.
Old Mar 30, 2005 | 02:14 PM
zvhrst's Avatar
zvhrst
if he gets ratchet system out of mk6 escort they are manualy adjustable, wont break again,
bit of a bugger to fit and alter but better in long run
Old Mar 30, 2005 | 02:50 PM
BUNJY's Avatar
BUNJY
thankyou boys, most helpful. makes sense, cos he had a look and his clutch cable seemed a bit slack, but not majorly and its only been on car a few weeks. does the mk6 escort one need much altering like, and how difficult is it? or will it all become clear when we set about it. also, ford will stock the part wont they?
Old Mar 30, 2005 | 03:25 PM
Owain's Avatar
Owain
Never fitted one, but ford will stock the part yes. Meant to be a total arse to fit, some people remove the drivers seat to do it.
Old Mar 30, 2005 | 05:47 PM
davecosworth's Avatar
davecosworth
IM BACK
you have to take the drivers seat out to change it.they did fit the manual adjuster to the n reg si feistas these are alot better but i would recommend takeing the dash out if you arnt familier with doing these (good luck)
Old Mar 30, 2005 | 10:18 PM
BUNJY's Avatar
BUNJY
right, well, go see mr ford tomorrow and attempt it friday afternoon when we both finish work then i guess. cheers for all your help
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
