oil pressure4x4 saff
Old May 11, 2004 | 06:52 AM
ricky's Avatar
ricky
Default oil pressure4x4 saff
can some one tell me engine just being built
new every thing done 2k sor far but iam a bit
conserned about my oil
pressure bran new hp oil pump with all the right bits in it
when cold it shows about 50 psi then when i drive it it stays at
a constant 40 psi then some times when it gets hot the pressure drops
to about 10 psi a bit worring i was told to put some stp in it
Old May 11, 2004 | 07:40 AM
Guinnless's Avatar
Guinnless
If the gauge is reading correctly then you have a problem. Forget the STP
Time to take the engine apart.
Old May 11, 2004 | 11:11 AM
Dilly's Avatar
Dilly
at idle when warm it should be at least 30 psi
Brickhouse
14
Oct 3, 2015 07:28 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
deathrider666
Sep 28, 2015 06:12 PM
