Cosworth fuel pump probs........
Old Mar 27, 2005 | 06:50 PM
CosKev3's Avatar
CosKev3
Default Cosworth fuel pump probs........
No power getting to my fuel pump
Where are relay/fuse please??????
Any other common faults that could cause this??????
Any1 know of any easy tests to do if fuse/relay is not at fault?????
Thanks
Old Mar 27, 2005 | 08:04 PM
Dilly's Avatar
Dilly
fuel pump relay is in the passenger footwell near the ECU - you should see 2 yellow relays - one is for the pump and the other is for the ECU
Old Mar 28, 2005 | 05:49 PM
CosKev3's Avatar
CosKev3
Cheers m8
Found the problem,the fuse holder had melted
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
Prickly_buzz
Aug 25, 2015 11:33 AM
kosienutter
31
Aug 22, 2015 09:55 AM
dlwarrior
Aug 5, 2015 10:19 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
