ARP Head nut & studs
Old May 12, 2014 | 02:28 PM
pabloXR's Avatar
pabloXR
TA 2008 2009 2012
Default ARP Head nut & studs
Our cossie engine is fitted with arp head nut & studs and not long studded. So my question is what sort of power / boost can this setup handle before we have to remove the engine to get it long studded.
Paul.
Old May 26, 2014 | 08:59 AM
andy2577's Avatar
andy2577
from what ive heard , they are good for high 400hp maybe more but depends what sort of power you want really ?
Old May 26, 2014 | 04:15 PM
DixieTheKid's Avatar
DixieTheKid
Pick-up P100 Power!
I was advised not to use them by the tuner and others. I have std head bolts for matt Lewis and will be nearly 500bhp. Hopefully
Old Jun 7, 2014 | 07:29 PM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Short studs tend to pull on the top of the block. With loads of boost the head lifts and trying to take the top of the block with it. Which then leads to cracks.
If your not running loads of boost they are fine.
Standard bolts will not like 500 bhp and the ends of the head tend to lift when using standard bolts. They work but for how long.
The fact is there is no better way to help prevent premature failure of a block than long studding it. Which obviously has the cost of a total rebuild which most people try to avoid.
If you have a good 200 block then my advise would be with high power is safety first. Last thing you want is to lose the block. If you have a 205 large core block then try your luck just like me... haha.
T4 2.2 bar boost 92mm pistons. Loads of fun until it pops. Done well so far tho.
Old Jun 7, 2014 | 08:39 PM
studabear's Avatar
studabear
Which car is that in jano?
Old Jun 8, 2014 | 03:59 PM
Versus_Creations
Ask me a question!
Rwdmk4.
Cosnada
Jan 7, 2016 05:30 PM
Nov 1, 2015 06:53 PM
DavidK
Sep 27, 2015 02:55 PM
little bram
Sep 27, 2015 07:45 AM
