uRGENT HELP NEEDED!!!
Old May 9, 2004 | 07:22 PM
K17SSE's Avatar
K17SSE
Default uRGENT HELP NEEDED!!!
I have just changed my engine and gearbox mounts on my escort cosworth .
I dropped the crossmember with the steering rack in situ and the suspension cahnged the mounts and now when i have started up the engine power steering fluid is bubbling up out of the tank????
What have i done are is it an air lock etc ????
Plaese help need the car on the road by tomorrow for the aces cafe!!!
Cheers PaulCR
Old May 9, 2004 | 10:42 PM
dave cos4x4's Avatar
dave cos4x4
I think if you open the cap,beware fluid may splill a bit, and turn lock to lock a few times this should get the air lock out.
this is how i did mine iirc.
Dave.
Old May 10, 2004 | 01:04 PM
Wangdian's Avatar
Wangdian
Remove the negative lead from the coil and crank the engine for a couple of seconds while turning the steering wheel. Method for bleeding power steering.
Old May 10, 2004 | 04:07 PM
K17SSE's Avatar
K17SSE
Cheers for that
Had also notice i had a leak on one of the jublie clips by the pump tighten that up and hey presto!!
Old May 10, 2004 | 09:01 PM
Wangdian's Avatar
Wangdian
All good
JoeyBoyden
Jan 4, 2024 02:36 PM
jessie_rs
11
Jun 3, 2019 04:57 PM
borboyous
Aug 22, 2015 11:17 AM
col93saphcos
Aug 7, 2015 03:21 PM
