Coil pack testing
Old Mar 31, 2014 | 05:28 PM
cozi500's Avatar
cozi500
Default Coil pack testing
Hi all has anyone tested a coil pack, the reason im asking is because i think mine might be goosed, its a wasted spark coil pack, with three terminals the centre pin is a pin has a 12v feed the outer two i believe are coil A and coil B, now the test i have done are resistance and continuity tests, Coil A has continuity with coil B is 0.3 ohms this correct it dont seem right to me surely they should be separate, correct me if im wrong.
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
jameswrx
Modellers Corner.
17
Oct 9, 2015 08:26 PM
