heater problems ??
Old Mar 28, 2014 | 09:05 AM
anthonym's Avatar
anthonym
Default heater problems ??
Hi guys am having heater problems on my mk5 fiesta electronically I think it's fine it just sometimes it works and sometimes it doesn't it's very sluggish and there is a knocking from inside the heater .... a good wack on the side seems to kick start it and make it work ... Just wondering if this is a common problem and is it worth trying to fix our should I just buy a replacement ..... cheers
Old Mar 28, 2014 | 09:22 AM
STeve's Avatar
Super Moderator
sounds like a the motor is at fault if a whack sorts it, common things on these are not normally the motor tbh as its usually the resistor pack or heater valve but tapping either of those wont do anything so simply sounds like a duff motor, just a few quid in any decent scrappy
Old Mar 28, 2014 | 09:47 AM
anthonym's Avatar
anthonym
Thank you will have get straight onto it am sick of guessing where am going when the windscreen steams up ha
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
