escort engine issues
Old Mar 12, 2014 | 03:19 PM
will_997's Avatar
will_997
Default escort engine issues
Hi all
after recently fitting a new engine to my escort 1.8 non turbo diesel van (1997)
I can't get it to run for more than a few seconds before it cuts out.
i've taken off the fuel pipe to the injector pump and pumped the primer till fuel comes out.
then cracked the injectors till there are no air bubbles
it will run for about ten seconds then cut out and only start again after about 5 mins any help would be greatly appreciated
thanks
will
Old Mar 14, 2014 | 09:02 PM
cabriolet's Avatar
cabriolet
immobiliser fella did you use your pump[ red chip in key ?]
JoeyBoyden
Jan 4, 2024 02:36 PM
Vincereese
Jun 1, 2023 09:14 AM
Bailes1992
Aug 16, 2015 07:14 PM
Vincereese
Aug 16, 2015 06:38 PM
Old ford
Jul 31, 2015 06:50 AM
