Revving on its own...
01-02-2014, 07:39 AM
RS TURBO
What could be that cause that a Ford Escort 18 TD engine revs on its own? Thanks.
01-02-2014, 08:47 AM
Resident Wrestling Legend
oil is leaking into the fuel and causing it to "diesel up"
find your leak, solve your problem
01-02-2014, 08:49 AM
http://en.wikipedia.org/wiki/Dieseling
01-02-2014, 09:38 AM
RS TURBO
how can I determine if oil is leaking in diesel?
01-02-2014, 09:42 AM
RS TURBO
any other causes maybe apart from this?
01-02-2014, 12:14 PM
Air peak perhaps?
Mist likely to be the turbo oil seal leaking and then the engine is running on due to the oil
Is it using much?
kosienutter
31
22-08-2015 09:55 AM
JoeyBoyden
18-08-2015 05:56 PM
Adam-M
22
10-08-2015 10:46 AM
CabrioTurbo
01-08-2015 11:04 AM
3door
11-12-2003 04:26 PM
