How to wire up a cooling fan
Old Jan 26, 2014 | 07:12 PM
john v's Avatar
john v
Default How to wire up a cooling fan
Hi all, I've just fitted a new radiator into my mk1 escort , it's got a fan attached to the front and a temp switch in the header, can anyone tell me how to wire it up and if I need a relay what one,
Thanks for any help
Old Jan 26, 2014 | 07:36 PM
doga-ot's Avatar
doga-ot
Here bud this is for twin fan but its exactly the same!
Old Jan 26, 2014 | 07:37 PM
doga-ot's Avatar
doga-ot
hope this helps
Old Jan 26, 2014 | 07:53 PM
john v's Avatar
john v
Brilliant, can't thank you enough, that's a job for tomorrow then.
Old Jan 26, 2014 | 08:02 PM
doga-ot's Avatar
doga-ot
No problem
Old Jan 26, 2014 | 08:35 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
you'd be better using the diagrams in the link below
http://www.aaroncake.net/rx-7/efaninstall.htm
Old Jan 26, 2014 | 09:46 PM
john v's Avatar
john v
Thankyou, that sounds like the way to go then as I like the idea of the fan staying on for a bit when the engines stopped running,
Thanks again
Old Jan 29, 2014 | 06:10 PM
Mk4 Rick's Avatar
Mk4 Rick
Nice diagram have you used this set up because I need to wire a fan in as well.
Old Jan 29, 2014 | 06:25 PM
Turbosystems
Super Moderator
Use the diagrams in the link above not the one posted by doga-ot
doga-ot's Avatar
doga-ot
not yet got it off a site was going too but now I've got a braided twin fan loom...
Old Jan 29, 2014 | 06:26 PM
Turbosystems
Super Moderator
use the diagrams in the link I posted
Old Jan 29, 2014 | 06:29 PM
doga-ot's Avatar
doga-ot
I got braided twin fan loom now, I said lol. That's why I didn't end up using it!
Old Jan 29, 2014 | 06:39 PM
st220kyle's Avatar
st220kyle
The fuse is in the wrong place in that pic isn't it?
Old Jan 29, 2014 | 07:05 PM
Mk4 Rick's Avatar
Mk4 Rick
Ive got a twin fan set up.So the diagram set up with allows the fan to run longer in the hot weather is this the best set up .Can some one simplify the diagram a bit lol.I get most of it except pin 85 and 86 and 30.I thought pin 30 was for the accessories
Old Jan 29, 2014 | 07:17 PM
st220kyle's Avatar
st220kyle
what diagram are you working from?
Old Jan 29, 2014 | 07:33 PM
Mk4 Rick's Avatar
Mk4 Rick
http://www.aaroncake.net/rx-7/efaninstall.htm this one first diagram lol
Old Jan 29, 2014 | 07:37 PM
st220kyle's Avatar
st220kyle
30 - 12v 30a supply
85 -(can be linked to pin 30)
86 - negative/earth which is switched by a thermostat
Old Jan 29, 2014 | 07:41 PM
GVK.'s Avatar
GVK.
You're just putting permanent feed to pin 85 (linked to 30) to allow it to run after being switched off.
87 is always the accessory whether it's a spot light, a fan whatever...
Old Jan 30, 2014 | 06:21 PM
Mk4 Rick's Avatar
Mk4 Rick
Cheers for your help.Im gonna get it wired up soon as because right now I have it on a switch and that's not good at all.Isnt the thermostat that's wired to pin 86 classed as an accessory as well
Old Jan 30, 2014 | 06:41 PM
GVK.'s Avatar
GVK.
86 in this case is going to ground through the thermostat.
As st22kyle posted previously!
Old Feb 1, 2014 | 05:56 PM
Mk4 Rick's Avatar
Mk4 Rick
When I did my conversiom on my fiesta mk4 I added the 2litre ecu and engine bay loom from the mondeo but the fan side of things was all messed up.So I want to go this way in adding a fan relay so every thing is fine again instead of using a fan on a switch.On the 2 litre blacktop thermostat housing is the fan switch on top of the housing or on the bottom and with my mondeo loom not having the original fan set up it wouldn't cause fuel problems would it like over fueling or running lean or run weird would it?
Old Feb 1, 2014 | 06:15 PM
st220kyle's Avatar
st220kyle
I have no idea, Thats one for GVK
Old Feb 1, 2014 | 06:27 PM
fraser9764's Avatar
fraser9764
I think doga-ot should remove that drawing in case anyone follows it
the fuse is in the wrong place and the fan switch will last 2 minutes, if that.
Old Feb 1, 2014 | 08:16 PM
opposite lock's Avatar
opposite lock
As above the 1st diagram shows the fan switch having direct feed running through it. The relay powers the fans not the switch .
edit-The battery feeds the fans the relay allows current to flow to them . Not the switch,that just controls the one side of the relay coil.
Old Feb 1, 2014 | 08:51 PM
doga-ot's Avatar
doga-ot
on my diagram it was short hand lol switch live meant (switched live) not a live with switch.... Any how as I said never used it in end bought a braided loom
Old Feb 1, 2014 | 10:41 PM
fraser9764's Avatar
fraser9764
You are still wrong though, the problem with your drawing is it shows the thermo switch inline with the fan, meaning all the current drawn by the fan motors will pass through the thermo switch. The switches can't take this kind of current and will fail. The thermo switch should be on the coil side of the relay,meaning the only current it sees is the few milliamps needed to energise the relay.
And the fuse should be the first thing in the circuit when the feed leaves the battery, any components or wiring before the fuse are unprotected should they short to earth.
And it doesn't matter if you didn't use it, it is still there for others to use. I just hope no one uses the drawing then has a problem causing a fire...
Old Feb 1, 2014 | 11:33 PM
doga-ot's Avatar
doga-ot
I just copied it of a page on here somewhere last year I got no clue on electrics
Old Feb 2, 2014 | 01:43 PM
opposite lock
GVK #18 is the one to use.
An SPST 40/30A 12V relay is what you need.
You can use 87 as your power in through to 30 or visa versa.
Same with 85 and 86 for activation. I prefer always using pin 30 for batt + its easier to remember. My live side of the coil i remember as 86 just like the world cup 'live' lol.
Old Feb 17, 2014 | 07:44 PM
Mk4 Rick's Avatar
Mk4 Rick
Gonna wire this up over this week some time.I have one question though when we talk about temperature switch do we mean the fan switch because ive heard these being called alsorts of things
Old Feb 17, 2014 | 08:21 PM
GVK.'s Avatar
GVK.
Yeh, don't wire it up to the coolant temp sensor (ECT)
whateveryoudo
Old Feb 18, 2014 | 12:32 PM
Mk4 Rick's Avatar
Mk4 Rick
whateveryoudo
Yeah so fan switch it is.I thought it couldn't be the ect sensor but thought id double check
Old Feb 18, 2014 | 08:49 PM
Mk4 Rick's Avatar
Mk4 Rick
Im not sure what to do with pin 86.The thermostat wire is all wired up to the ecu isn't it
Old Feb 19, 2014 | 12:30 PM
martysmartie's Avatar
martysmartie
Pin 86 is the relay ground, which is switched via the thermoswitch, so it connects to here and the other side of that switch to ground.
It is totally independent of the ECU, it is merely a switch that completes the relays circuit.
In modern cars this is a different story and these switches are mostly a thing of the past, instead the CTS reference is used and the ECU activates the fans when required.
Martin
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Chas
Oct 5, 2015 07:13 PM
IainRS1700T
Sep 25, 2015 06:44 AM
