Draining IB5 Gearbox Oil?
Old Dec 23, 2013 | 05:43 PM
Bailes1992's Avatar
Bailes1992
Default Draining IB5 Gearbox Oil?
I have a new gearbox for the missus KA as she's lost 2nd (You can feel it grinding on the layshaft but it never slides in).
I'm assuming that the KA uses an IB5?
I want to drain the oil out of the gearbox before I fit it to the car and maybe replace the driveshaft seals.
The gearbox has come with the inner CV joint 'cups' fitted but I can't work out how to slide them out of the gearbox?
My Pugs had a bolt that you ondone 90° and the driveshaft would slide out but this doesn't seem to have anything?
Do I just need to give them a bloody hard pull or am I missing a trick?
If I don't replace the driveshaft seals what's the next best way to drain the gearbox oil?
Bare in mind the gearbox is sat in a garage and not in the car.
Cheers, Bailes.
Old Dec 23, 2013 | 05:56 PM
Get a good pry bar and flick them out.
Old Dec 23, 2013 | 06:04 PM
Churtz's Avatar
Churtz
Yeah just pop them out with a pry bar
Matt
Old Dec 23, 2013 | 06:05 PM
Churtz's Avatar
Churtz
There is a drain plug on there too though....
Old Dec 23, 2013 | 06:19 PM
botters's Avatar
botters
competant bodger
ive never seen a drain plug on an ib5
yes just pop shafts out with a pry bar
Old Dec 23, 2013 | 06:40 PM
GVK.'s Avatar
GVK.
No drain plug on an ib5
Some people may remove one of the detent plungers on the front of the box but tbh, I'd leave well alone, just drain from where driveshaft goes in.
Old Dec 23, 2013 | 09:03 PM
Bailes1992's Avatar
Bailes1992
Cheers guys!
Is there any reason I couldn't use the inner CV joint 'cups' that came on this second hand gearbox (Is there a proper name for these?) with the inner CV joints fitted to the car?
Or should I take the cups out of the broken gearbox and fit them to the new one?
Old Dec 23, 2013 | 10:04 PM
You could use the new ones. Just make sure there is plenty of grease in them.
Old Dec 24, 2013 | 07:16 AM
STeve's Avatar
Super Moderator
never
Old Dec 24, 2013 | 07:20 AM
JamesH's Avatar
JamesH
I'd use the flanges that came with it. Considering you're already taking one out to drain the oil, may as well change the seals. They aren't expensive. I had one leak on my Golf, with only 90k on the clock!! Made a mess
Old Dec 24, 2013 | 07:34 AM
blueovalman's Avatar
blueovalman
Although there is not a drain plug, there is a filler plug located behind a plastic cover where the gear linkages are connected to the box
Old Dec 24, 2013 | 08:56 AM
Bailes1992's Avatar
Bailes1992
Could I undo the filler plug and tip the gearbox up so it drains out the filler?
I don't quite know what goes in inside a gearbox and pretty inexperienced by all accounts
Old Dec 24, 2013 | 09:12 AM
blueovalman
You should be able to yes, but it will take a while so I would suggest support it with something rather than hold it cause after a while it gets heavy
Old Dec 24, 2013 | 12:02 PM
Bailes1992's Avatar
Bailes1992
Cheers guys!
Changed the clutch on this KA in the summer so should be a piece of piss to change as I greased everything up.
Don't understand fords logic by not fitting a drain plug to the IB5 but such is life!
I changed the oil in the gearbox on my MMT6 in about 10mins!
TPM961
Jan 15, 2018 10:50 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Rich Coveney
Ford Mondeo Including ST
Sep 15, 2015 05:39 PM
Flateric_2002
Sep 15, 2015 08:41 AM
Adam Graham
Sep 6, 2015 06:04 AM
