Focus st headlight help please :)
Old Dec 12, 2013 | 08:28 AM
Miss Black Puma's Avatar
Miss Black Puma
Default Focus st headlight help please :)
Hi!
I've got a Focus ST3 and the xenon headlights are moving up and down randomly, I noticed it while sat in traffic. When I start the car they don't come up as they should. The car has sensors underneath which are fine, I disconnected the battery and reconnected it and reprogrammed the module with IDS, it worked ok a few times but then went back to doing its own thing. I think it must be a fault with the levelling control module but can't seem to find it!! Had a look behind the instrument cluster and had the fuse box out and looked behind that but there's no sign of it, I know it's a little black box, I've seen pictures of it online. Has anyone else had this problem or know where I might find the module??
Thanks!! Claire
Old Dec 12, 2013 | 05:07 PM
Miss Black Puma
Any help would be really good, thanks,
Claire
Old Dec 12, 2013 | 06:16 PM
dojj's Avatar
dojj
Resident Wrestling Legend
you need to go back to ford to get them reset because that's what they'll do when you disconnect the battery
Old Dec 12, 2013 | 06:17 PM
dojj's Avatar
dojj
but the thing that may be at fault will be attached to the suspension, normally the rear beam somewhere from memory
Old Dec 12, 2013 | 06:48 PM
Carlos-Titx's Avatar
Carlos-Titx
Opposite corners the leveling sensors I think. Front right rear left. Or front left rear right.
Old Dec 12, 2013 | 08:07 PM
Miss Black Puma
I disconnected the battery which made it work short term but then for reprogrammed it using ids and again it only worked short term does anyone know where the actual module box is? Tried the sensors
Thanks again!
Old Dec 12, 2013 | 08:10 PM
dojj's Avatar
dojj
have you tried to unplug the sensors to see if that makes them stop?
on my mondeo i simply fitted a manual adjustable switch to level them up, i know it may not be strictly legal but it hasn't failed an mot in 3 years
Old Dec 13, 2013 | 07:51 AM
Miss Black Puma
Thanks for your help
Just wish I would find the module lol!
Old Dec 13, 2013 | 05:12 PM
dojj's Avatar
dojj
http://www.talkford.com/topic/205178...auto-leveling/
Have a read of this
OK so its for a Mondeo but your issue seems to be the as posted further down the thread
Old Dec 15, 2013 | 07:51 AM
Miss Black Puma
Have a read of this
Thanks everyone
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
Mile30
69
May 13, 2017 08:44 PM
Tank Mike
Ford Focus ST Parts for Sale
May 18, 2016 09:38 PM
Sp3no
Sep 27, 2015 07:23 PM
Tank Mike
Sep 26, 2015 08:07 AM
