V6 12v 2.9 sump gasket same as 2.8 sump gaskets?
Old 01-12-2013, 09:46 AM
Jk38
Jk38's Avatar
Default V6 12v 2.9 sump gasket same as 2.8 sump gaskets?
Are the sump gaskets for the 2.8 and
2.9 cologne engines the same ?
Old 01-12-2013, 05:34 PM
CosworthGuy
3dr Cosworth owner
CosworthGuy's Avatar
Im sure their not mate. The 2.3 and 2.6 v6 gasket it the same as the 2.8 as they were all the essex v6 whereas the 2.9 was the cologne v6. Totally different engine as far as Im aware
Old 01-12-2013, 08:23 PM
JFB Tech
Not entirely sane
JFB Tech's Avatar
2.3, 2.6, 2.8 and 2.9 are all Cologne engines, the Essex engine was the old 3 litre used in the Capri. I'm not sure if the sump gaskets are the same. If it's 4wd then there isn't a gasket used at all, it creates too much flex for the front diff mounted on the side of the sump.
Old 01-12-2013, 08:27 PM
stucapri2.9iTT
stucapri2.9iTT's Avatar
2.9 and 2.8 are the same, i run a 2.8 sump and pick up on my 2.9 rwd
stuart
Old 01-12-2013, 08:47 PM
mk2 cossie
mk2 cossie's Avatar
yup, the gasket face is the same for all the Colognes. Although there is a 1 piece rubber one listed for 1 model that is the better one to use
Old 01-12-2013, 10:10 PM
dojj
Resident Wrestling Legend
dojj's Avatar
Use sealant rather than just the gasket
You really don't want to change one again and again
01-11-2015 06:53 PM
Mc5506
05-10-2015 09:57 PM
XR4
Ford XR Range
01-10-2015 12:46 PM
DAZZER
30-09-2015 08:43 PM
youngben
27-09-2015 09:37 PM
Quick Reply: V6 12v 2.9 sump gasket same as 2.8 sump gaskets?
