l8 ecu no power
Old Nov 28, 2013 | 08:45 PM
whizzisat114's Avatar
whizzisat114
Default l8 ecu no power
Hi guys im powering up my engine loom and I cant seem to get an earth to the ecu or fuel pump relays
I have no sensors plugged in at this time.
If I earth the relays I get full power to all the sensors/fuel pump.
Ive been over wiring and the schematic but nothings jumping out at me
Any help would be great
David
Old Dec 1, 2013 | 09:10 AM
opposite lock's Avatar
opposite lock
Pin 10 on the ECU is the ecu 'power relay drive' earth controlled I assume going by BIGTURBO site.
Old Dec 8, 2013 | 03:27 PM
whizzisat114
Got no earth output from ecu to ign or fuel pump relays
As said I have continuity checked the loom and all is good but I don't have any sensors plugged into it.
Would this cause the problem?
Old Dec 8, 2013 | 03:55 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
http://www.cannell.co.uk/Ford_Worksh...sis%20Info.pdf
Old Dec 8, 2013 | 03:56 PM
gingerturbo
Try the link I posted it has a small loom diagram which may help
Old Dec 8, 2013 | 05:29 PM
martysmartie's Avatar
martysmartie
If your grounding the relay and it's working then clearly there is a problem with it grounding via the ECU (pin 10) as said.
First verify this connection is good as well as checking the ECU itself has a good ground.
Fuel pump relay is pin 28, you should not be grounding this relay, however, when you had power before this should have powered up the ECU?
Remember the pump will only 'prime'.
Martin
Old Dec 8, 2013 | 05:50 PM
james kiely's Avatar
james kiely
do the sensors need to be in place for the ecu to do its check before it will allow the pump to be triggered ?
Old Dec 8, 2013 | 05:58 PM
martysmartie
Yes, it will not prime without information from the CPS.
Also the CTS can alter the duration of the prime.
Martin
Old Dec 8, 2013 | 06:01 PM
james kiely
i remember you saying that before martin ,top tip mate
Old Dec 8, 2013 | 06:04 PM
martysmartie
And well spotted for missing what I overlooked
Martin
Old Dec 8, 2013 | 06:31 PM
whizzisat114
Thanks for the info guys ill plug the sensors in and try it next time im in the garage : 0 )
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
phil51
Ford Focus Diesel
Oct 2, 2015 01:00 PM
Iain Mac
Sep 30, 2015 09:39 PM
dojj
Sep 29, 2015 10:32 PM
deathrider666
Sep 28, 2015 06:12 PM
