Cossie Engine Loom Resistnace Results
Old Sep 15, 2013 | 06:23 PM
kosienutter's Avatar
kosienutter
Last Time, Get Off PF FFS
Default Cossie Engine Loom Resistnace Results
Have just finished going over the loom for resistance. A mate at work said anything over 2.0 you should be looking into why. Is he right?????
Here's my readings I have got.
(SENSOR, ECU PIN, RESISTANCE) (INFO)
TPS 11 1.0
TPS 17 1.0
TPS 30 1.0
MAP 15 1.2
MAP 11 1.1
MAP 30 1.1
INJ 1 35 0.8
INJ 1 20 0.8
INJ 2 32 0.9
INJ 2 20 0.8
INJ 3 33 0.9
INJ 3 20 0.8
INJ 4 18 0.8
INJ 4 20 1.1 (With wire break temporarily fixed)
ACT 31 0.7
ACT 11 0.8
CRANK 3 0.8
CRANK 4 0.9
ISCV 34 1.1 (Only Just) (Could go to 1.7)
ISCV 20 0.8
KNOCK SENSOR 22 1.7 (Connection Needs a Clean)
KNOCK SENSOR 6 0.9 (1 of 4 pin Connections Missing)
PHASE 5 0.9
PHASE 23 0.9
ECT 29 0.9
ECT 11 0.8
LAMBDA 2 1.0
LAMBDA RELAY 1.0
LAMBDA GROUND 0.9
AMAL Vv 16 0.9
AMAL Vv RELAY 1.0
IGN MODULE 25 0.9
IGN MODULE 24 0.8
IGN MODULE (TO ALL IGN AMP CONNECTIONS FOR WASTD SPARK) 0.9
IGN MODULE GROUND 0.8
IGN MODULE LAMBDA 0.9
Do these readings seem ok to you guys?????
Old Sep 16, 2013 | 05:46 AM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
Seams like a good loom, yeh you shouldn't be seeing anything above 2.0ohms unless you have a thicker gauge wire in the loom, or the wire runs twice the length of the car, or a fault
Old Sep 16, 2013 | 07:45 AM
kosienutter
Happy days. Thanks
Old Sep 16, 2013 | 12:47 PM
martysmartie's Avatar
martysmartie
Thicker gauge wire has less resistance!
Martin
Old Sep 16, 2013 | 05:39 PM
gingerturbo
Martin
Yes it does my bad I had just woke up lol
big_Rad
Sep 15, 2017 09:36 AM
kosienutter
31
Aug 22, 2015 09:55 AM
Topjoe9
Aug 20, 2015 02:38 PM
muz
Aug 16, 2015 12:57 PM
MARKYMARKONE
Aug 2, 2015 09:33 PM
