Differences with zetec inlet?
Old Aug 18, 2013 | 10:10 PM
RS16iDale's Avatar
RS16iDale
Default Differences with zetec inlet?
Im a lil confused on which plastic zetec inlet manifold to use on my 2ltr blacktop turbo.
The one that come with the engine is broke so cant use that.
My friend gave me another manifold which is the earlier 2 piece type but my throttle body wont fit,the bolt that holds the throttle cable on hits against one of the primarys.
Is this why on a frs they use the spacer plate between throttle body and manifold?
And why is it that some have more outlet pipes than others,iscv in different place etc
Old Aug 18, 2013 | 10:13 PM
rsmark86's Avatar
rsmark86
you want a 1 piece mondeo 2ltr unit, i got one complete for £35 on ebay from mts motorsport
then the fiesta rs turbo fuel reg bolts straight to the fuel rail and with an adaptor plate you can even use the fiesta rs turbo tps
my friend made the adaptor plate for the tps in minutes lol, thats if you wanted to use ofab ect otherwise if using aftermarket management just use the zetec one
Old Aug 18, 2013 | 11:25 PM
SBT83's Avatar
SBT83
Not Crazy, just Unwell
I have a 1.8/2.0 blacktop inlet. Same as frs inlet that I'm not using
Old Aug 19, 2013 | 05:52 AM
rsmark86's Avatar
rsmark86
get it brought
Old Aug 19, 2013 | 12:04 PM
RS16iDale's Avatar
RS16iDale
cheers mark,yea ive already bolted the fiesta regulator to the rail and using focus rs injectors,will be running on omex
is it the one piece type sbt83? also is it complete?
Old Aug 19, 2013 | 12:14 PM
SBT83's Avatar
SBT83
It's a bare 1 piece blacktop item. Just the actual inlet! Your tb, injectors and fuel rail will be a straight fit. I've reused all the ancillary parts for my build, so the inlet is spare
Old Aug 19, 2013 | 12:21 PM
SBT83's Avatar
SBT83
Same as this
But bare
Old Aug 19, 2013 | 12:52 PM
RS16iDale's Avatar
RS16iDale
how much you after?
Old Aug 19, 2013 | 01:05 PM
SBT83's Avatar
SBT83
Originally Posted by RS16iDale
how much you after?
Pm'd
Old Aug 19, 2013 | 10:42 PM
rsmark86's Avatar
rsmark86
get that one and swap all the bits off your two piece onto it........ job done, i couldnt use mine as it done fit in a mk3 fiesta zt
Old Aug 19, 2013 | 10:45 PM
SBT83's Avatar
SBT83
I've gone rover inlet so it's no use to me now!
Old Aug 20, 2013 | 05:49 AM
rsmark86's Avatar
rsmark86
no worries still a good choice mate
155lee
Oct 27, 2015 04:55 AM
Chopshop85
Sep 12, 2015 06:42 PM
Si B
Sep 12, 2015 06:49 AM
grishenko45
Sep 9, 2015 12:58 PM
BRAM
Sep 8, 2015 07:11 AM
