engine revs when clutch depressed fiesta 04
hi got an 04 plate 1.4 fiesta and when im driving and change gear i come off the throttle and depress the clutch, but the revs pick up quite a bit as though ive depressed the throttle again, goes into gear ok though......would appreciate some help
Not Crazy, just Unwell
Sometimes they do. Hydrolic clutches run off the brake system. I.e. to top both up you fill the brake fluid reservoir. My toyota does it slightly, it's the engines way to stop it from stalling at low revs. If its significantly higher like over 1k revs that's a different matter. Hope this helps
Lol you don't need a manual to see that. Open the bonnet a look at the right hand side of the block. Is there a chunk of metal bolted between the block and the air pipe with a coiled up wire around it? It will move when some one accelerates for you.
competant bodger
nor do throttles bolt to the block
Not had these hanging revs up as yet, the older ones were common for it.
As Botters says, electronic throttle on them, Ford call the pedal APP (accelerator,pedal,position) warranty admin bloke asked me once what APP meant on one of my write-ups, I just said "Another piece of plastic"
Worth checking if clutch pedal switch is there and plugged in/wires connected.
competant bodger
They were shit when that model of Fiesta first came out, loads of them would suddenly have a loss of throttle and "EAC FAILURE" on the dash, some had pedals, some had throttle bodies, some had engine bay wiring looms, some had PCMs.
JoeyBoyden
18-08-2015 05:56 PM
