How to check rs turbo fuel relay without a car
Old 22-07-2013, 09:14 PM
bil_s2
bil_s2's Avatar
Default How to check rs turbo fuel relay without a car
Hi,
Having sold my s2 RS Turbo last year, I have found 4 pink fuel relays in a garage clear out.
Im sure they work and were kept as spares but would like to test them before advertising them on EBay. As I don't have a car to test them on, is there a check I can make with a multimeter to determine if they are working or faulty?
Thanks for reading...
Billy
Old 22-07-2013, 09:44 PM
dholdi
dholdi's Avatar
Do you have a wiring diagram as you will need to know which 2 pins need 12v applying to energize the relay. You could then test with a multimeter to see if the relay is closing the circuit across the other 2 pins.
To do it properly though you would need to simulate the current draw across the relay that the fuel pump would draw to ensure the relay is functioning correctly.
kosienutter
31
22-08-2015 09:55 AM
taylora1409
12-08-2015 12:06 PM
Zoggon
10-08-2015 10:39 AM
CabrioTurbo
01-08-2015 11:04 AM
ginger1979
31-07-2015 09:56 PM
Quick Reply: How to check rs turbo fuel relay without a car
