2ltr DOHC bolt?
Old May 19, 2013 | 11:08 PM
Zuzana's Avatar
Zuzana
Default 2ltr DOHC bolt?
Hi, I have a 1991 Sierra 2ltr DOHC, a bolt has punched a hole through the lower front cover plate close to the pulley wheel???
I have recovered it and repaired the hole,changed oil/filter and the car seems to be running fine(for now).
Can some one please tell me where this bolt came from??
I have attached link with a photo of the bolt next to a penny.
Any help would be greatly appreciated
Zuzana
Old May 20, 2013 | 12:24 AM
JFB Tech's Avatar
JFB Tech
Not entirely sane
From memory, I think that's the upper timing chain guide bolt. The guide often breaks there but I haven't seen the bolt fall out before.
Old May 20, 2013 | 05:49 AM
Zuzana's Avatar
Zuzana
Thanx JFB Is there a way i can check that without removing the cylnder head maybe just by removing the rocker cover?
Old May 20, 2013 | 06:10 AM
rik-rs's Avatar
rik-rs
looks like it could be one of 4 bolts...
same engine as mine...
Old May 20, 2013 | 08:21 PM
JFB Tech's Avatar
JFB Tech
Not entirely sane
In the pic above, bolts marked 20 will be visible with just the rocker cover removed. On all of my DOHCs they never had the bolt 20 which goes through the top centre chain guide (item 10), the guide was just clipped on. Bolts 19 & 21 will only be visible by removing the lower timing case cover (necessitating removal of the crank pulley which will need a new stretch bolt when re-fitting). If yours is from the top of the right hand chain guide, you will need to remove the upper timing case cover to replace it.
Hope this helps.
Old May 20, 2013 | 09:06 PM
doga-ot's Avatar
doga-ot
Sorry to hijack but where is the fuel pump relay on these as i cannot find mine for love nor money! Under glovebox are 2x small yellow relays, a small black and a small grey relay cannot find anymore under dash and none in engine bay
Old May 20, 2013 | 09:10 PM
dojj's Avatar
dojj
Resident Wrestling Legend
it'll be the top timing chain guide bolt, number 20 in the pic but on the long guide on the right
had the same thing happen to a car i bought for free
you need to threadlock them into place when you reassemble and i wouldn't drive it in that condition as the guide will break and trash the engine
the complete chain guides and bits should come in at less than Ł140 for a complete front end rebuild so you may as well do it
about 3 hours work all in as long as you can get the front pulley bolt out
Old May 20, 2013 | 09:11 PM
dojj's Avatar
dojj
they will be the auxiliary relays for things such as the abs and stuff that don't live in the fusebox
not sure where the relay for the pump is as its been THAT long since i fiddled with sierras
Old May 20, 2013 | 09:50 PM
JFB Tech's Avatar
JFB Tech
Not entirely sane
Fuel pump relay is one of the small brown relays in the fuse box. From memory, I think there are two of these relays in there, can't remember which one it is. I think the guide in the lid of the box marks it with a little book symbol.
Old May 21, 2013 | 07:54 PM
doga-ot's Avatar
doga-ot
In my fuse box there are 2 tiny brown relays and none of them have a book symbol only 1 of the tiny blue relays has a book the other book is a 30amp fuse
Old May 21, 2013 | 08:44 PM
JFB Tech's Avatar
JFB Tech
Not entirely sane
Stand corrected on the little book symbol but one of the small brown relays is definitely the fuel pump one.
Old May 21, 2013 | 09:01 PM
doga-ot's Avatar
doga-ot
ok cheers will have a look tomo
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
Iain Mac
Sep 30, 2015 09:39 PM
DavidK
Sep 27, 2015 02:55 PM
little bram
Sep 27, 2015 07:45 AM
