Help required. Door lock issues
Old Mar 13, 2013 | 02:19 PM
Peter Hodge's Avatar
Peter Hodge
Default Help required. Door lock issues
I have an issue with the drivers door lock. When I lock the doors from inside using the lock on the door handle, the doors all lock. However when I try to unlock the doors using the same lock it doesn't work. Normally when the door Handle gets to a certain position, around half way normally, the door lock pops open but no matter how much you pull the handle the lock never opens. Oddly the passenger door lock opens when you pull the passenger door handle.
Thanks in advance.
Pete
Old Mar 13, 2013 | 03:28 PM
dug112y's Avatar
dug112y
passionford pro
is it on a focus?
if yes it needs a new door latch assy....common issue
Old Mar 13, 2013 | 06:45 PM
Peter Hodge
Sorry I should have said. It's a mk3 mondeo. Do you think that's still whats wrong with it?
Old Mar 13, 2013 | 07:46 PM
dojj's Avatar
dojj
Resident Wrestling Legend
you may have just popped the safety cover on the control cable
it's got a little red tab which sometimes comes adrift which means that you can't open the door from the inside as the handle won't allow enough movement
if it's only the drivers door you can't open from the inside then this will almost certainly be the culprit
the cable is about £8 from ford, just be careful when fitting it as the plastic can easily snap, rendering your new purchase useless
if it's just general door locking issues regarding the central locking then you will find it's almost certainly the central door locking module, built into the drivers door lock assembly
replacement is the only viable solution, either second hand or new, second hand is much cheaper and easily doable with a set of screwdrivers and some small pointy metal prongs
JK12
33
Apr 26, 2021 12:09 PM
Nov 5, 2015 08:12 PM
xrmalin
Sep 13, 2015 06:52 PM
gingeRS
Sep 4, 2015 06:29 PM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
