3 door Power Steering Help please.
Old Mar 1, 2013 | 03:16 PM
andym's Avatar
andym
Default 3 door Power Steering Help please.
Help!!
i am putting my 3 door back together and have a problem with power steering.
for the 1st 5 mins everything was ok and the the steering went siff and the pump stopped making the wuring noise on full lock.
steering pump i thought, changed the pump and bingo it worked and made the wuring noise on full lock, but after about 5 mins it stopped working again
i have now swapped the rack and still the same.
any Ideas??
Old Mar 1, 2013 | 04:51 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
I had this with an old pump that had been stood dry! The vains inside had got stuck in place and could not move about as they should.
I took it apart and cleaned it all up and it worked fine
Old Mar 1, 2013 | 04:54 PM
BRAMMER's Avatar
BRAMMER
It's all fitted up right etc and in line - seems odd to keep repeating the same symptoms
Old Mar 1, 2013 | 07:08 PM
andym's Avatar
andym
Yeah all fitted correctly, you can't get it wrong as the ports are a different size.
Old Mar 1, 2013 | 07:09 PM
andym's Avatar
andym
How do you take it apart?
mint_s2
Sep 2, 2015 08:58 AM
YODI
Aug 30, 2015 01:12 PM
Jay,
Aug 24, 2015 05:26 PM
borboyous
Aug 22, 2015 11:17 AM
Old ford
Jul 31, 2015 06:50 AM
