Turbo Whistling
Old Feb 26, 2013 | 01:32 PM
skelator52's Avatar
skelator52
Default Turbo Whistling
just realised ive posted this in the wrong section
https://passionford.com/forum/ford-m...o-whistle.html
this happened last week bearing in mind i've done nothing and it seems fine now or so I think.
was driving through to durham from Newcastle got on the a1 speeded up and left a lot of black smoke, about 20mins-half an hour later got to durham accelerating up there was no boost and the turbo started to make a whistle sound.
every time I accelerated past 2000rpm the turbo made the whistle sound and there wasn't any boost. got it home opend the bonnet and noticed the pipe going to the wastegate actuator was nipped under the engine cover so moved it and didn't make any difference the higher the revs the higher the whistle.
Friday morning was showing a friend and started revving it up black smoke out the exhaust then something metal went through the exhaust could hear it ping out.
took it for a drive no whistle and car seems to be boost ok.
any thaughts? just im abit worried as to what it could be its something serious.
its mondeo zetec s 02 83000 on clock
thanks
Old Mar 4, 2013 | 07:30 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
Turbo whistle is normally created by a hairline air/vacuum leak or the turbine shaft out of balance, you have may of even sucked up a small stone or equivalent and causing the wastegate to wedge open and the noise you heard was it clearing
Old Mar 5, 2013 | 09:44 AM
skelator52's Avatar
skelator52
When driving im now sometimes gettin a loss of power when accelerating and the cars juddering I easw off the pedal and then straight back on and its fine again but its starting to happen more often and im.also getting white smoke on acceleration
Old Mar 5, 2013 | 05:31 PM
gingerturbo
It's the turbo water fed
Old Mar 6, 2013 | 02:50 PM
skelator52's Avatar
skelator52
water fed?? whats that
Old Mar 6, 2013 | 05:18 PM
gingerturbo
On some turbo cars they have a water feed going through turbo
Old Mar 6, 2013 | 05:32 PM
macrs's Avatar
macrs
Are you getting any engine management/flashing glow plug lights?
I've just had to replace the EGR valve at 90k, car was smoking and loss of power, with flashing glow plug light. New valve and its fine..
Also, the hose from the intercooler to EGR valves are prone to splitting, but the split only opens up when the turbo is boosting... But you did say you checked that...!?!
If none of those are your problem, you may have a poorly turbo...
Old Mar 7, 2013 | 12:51 PM
skelator52's Avatar
skelator52
nope no lights and checked all the pipes I could. however I am getting a loss of power if I sit at speeds after a short time it lacks power and judders but if I come off the pedal and back on the power is there and no juddering.
Old Mar 7, 2013 | 05:37 PM
gingerturbo
I'd get ya turbo and actuator checked or do it yourself
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
