what car will a st170 engine fit in?
Old Feb 24, 2013 | 03:45 PM
16vzetec's Avatar
16vzetec
Default what car will a st170 engine fit in?
ive just picked up a st170 complete engine and loom.
but i have no car lol.
what car shall i fit it in?
im thinking that as its got rear starter that it will be a job to fit into some models.
will it fit into a ka? fiesta? escort?
without too much modifying preferably.
focus is an option i spose but i was thinking of something lighter.
whats your opinions?
Old Feb 24, 2013 | 03:47 PM
m11rcm's Avatar
m11rcm
What abt a puma you can pick them up cheap now.
Old Feb 24, 2013 | 03:50 PM
X8MRK's Avatar
X8MRK
How strange i was thinking will a st170 go into a kit car. I'm looking at a kit car on eBay which i fancy ago at & i dont really want to drop a bike engine in.
Old Feb 24, 2013 | 04:09 PM
16vzetec's Avatar
16vzetec
Yes been looking at them but what box would i use?
Old Feb 25, 2013 | 06:49 PM
16vzetec's Avatar
16vzetec
I meant what gearbox?
Old Feb 25, 2013 | 06:52 PM
doga-ot's Avatar
doga-ot
best gearbox for st170 is the 6speed it came with bud also why not throw it in an escort mk3/4 or 6 or even theres a clean mk2(mk4)orion on here for around Ł500 it will go in that
Old Feb 25, 2013 | 06:55 PM
16vzetec's Avatar
16vzetec
6 speed wont fit in anything but focus wothout lots of mods
Old Feb 25, 2013 | 07:30 PM
doga-ot's Avatar
doga-ot
Not true bud i had one on an rs2000 engine in my mk4 escort granted yes you do have to do a few mods but nothing major and well worth it
Old Feb 25, 2013 | 07:41 PM
doga-ot's Avatar
doga-ot
or go mtx(frs)gearbox
Old Feb 25, 2013 | 10:03 PM
rs_traynor's Avatar
rs_traynor
stage4 2wd cosworth
always said ''if'' i fucked my focus on track id strip it and put the supercharged st170 engine and 6 speed box along with the frs front seats in a mk1 or mk2 fiesta
Old Feb 26, 2013 | 06:50 AM
gup's Avatar
gup
What about a escort van
Do a little sleeper
Old Feb 26, 2013 | 07:37 AM
m11rcm's Avatar
m11rcm
Am sure you could use a rs turbo box a think it would go straight in no mods a think the puma has a gear linkage and not cables like the later ib5 and the mtx out of a focus.
Cheers marc
Old Feb 26, 2013 | 08:39 AM
Oranoco's Avatar
Oranoco
We fitted an ST170 engine to my brothers missus Escort GTi (Mk6). It was NOT in any way a straight forward job. Everytime we overcame one hold up we fell straight into another, this may have been compounded as we wanted to retain the airconditioning. Engine mated up to an IB5 box and I think we used a standard RS Turbo clutch. At present the car is running on a stock 2 litre Mondeo ECU which oddly on the rollers at Evolve produced a very nice power and torque curve with nice fueling. Saddly only made 150bhp but with no cam timinng adjustment we were quite pleased. Have some throttle bodies and DTA management to go on at some point in the near future.
Old Feb 26, 2013 | 08:52 AM
RichieST's Avatar
RichieST
I've always wanted to see a proper sleeper made out of a ford fusion, haven't seen one before!
Old Feb 26, 2013 | 11:27 AM
Zetec_mk4_XR3i's Avatar
Zetec_mk4_XR3i
Bolts straight up to an RST box which makes it a front starter, which means it will fit in most things! In saying that, this means you can't use the ST170 4 branch manifold as this would foul the starter.
Its essentially a black top Zetec so the rear mount needs modded for whatever it goes into...nice conversion in a mk5 Fiesta Zetec S or something like that?
Old Feb 26, 2013 | 11:31 AM
7sean7m7's Avatar
7sean7m7
^ Mk5 Zetec S gets my vote!
Old Feb 26, 2013 | 03:59 PM
SPARKS's Avatar
SPARKS
Mk1 fiesta, will fit with a few mods, I'm pretty sure I've seen a mk1 or 2 fiesta running a st170 engine and 6 speed box. Could always run rst box start motor is in the way a bit, but isn't really a major drama...
Old Feb 26, 2013 | 04:02 PM
gjh's Avatar
gjh
mk2 escort 4 door, keep it as big a sleeper as possible, apart from a little lowering and some laser 4 spoke wheels, you know it makes sense!
Old Feb 26, 2013 | 07:39 PM
16vzetec's Avatar
16vzetec
i was thinking the mk6 escort is the closet fit.
its rear starter box so thats easy.
the engine mount is no issues.
the only issues i can forsee are water pumo and oil pump angles.
any more info on this escort conversion please?
i wont need aircon, will be a track day car you see!
Old Feb 26, 2013 | 07:40 PM
16vzetec's Avatar
16vzetec
i dont want to do loads of chopping and welding, plus it needs to have injection fuel tank etc so it gets invloved then
Old Feb 26, 2013 | 07:42 PM
16vzetec's Avatar
16vzetec
i didnt think the starter will fit in the front coz the block is different shape
Old Feb 27, 2013 | 08:12 AM
Zetec_mk4_XR3i
I never came across any problems mate, all bolted up perfectly. I'm actually still using the 1.1 starter which may be a little smaller, but still works great.
I use an ashley 4 branch and no clearance issues with it or starter
Old Feb 27, 2013 | 09:18 AM
16vzetec's Avatar
16vzetec
Id like to use std management. i have it all here but not sure how i can use it if i change inlet manifold
Old Feb 27, 2013 | 10:40 AM
big_wasa's Avatar
big_wasa
I am working on my shoe string budget rwd St170 at the moment.
Ive been wiring up the oem ford ecu's into kitcars for years so the plan is to use the oem ecu to control the vvt and the dsi. I hope to get the full 170bhp with a decat and a dream science / Blufin remap.
So why bother with the oem ecu when any after market ecu and a vvt delete will have it over 200bhp ? well its cheap its plug and play and anything other than WOT it drives much better.
When I say cheap I mean the ecu and loom will cost me less than an omex 600 plug.
So first job before I spend to much cash is can I turn the pats on and of bassed on the work ive done before.
Answer=yep
Next job, can I work out the wiring.
Answer=yep http://i442.photobucket.com/albums/q...9-30124048.jpg
http://i442.photobucket.com/albums/q...psab3917ee.jpg
http://i442.photobucket.com/albums/q...ps2cfbf267.jpg
Next job, chop the loom up and remake it to fit a 7= done.
Now at this stage I hadnt bought an engine and I need to know if I can get the ecu to run an engine. So I test fired it on the silvertop.
Ive now bought an engine
http://i875.photobucket.com/albums/a...psbf27e878.jpg
And ive picked up a spare sump to chop up to clear a front mount starter and a couple of single mass flywheels.
http://i442.photobucket.com/albums/q...ps00b9f11e.jpg
http://i442.photobucket.com/albums/q...ps99eb6e66.jpg
I plan on mounting it up as a bench engine to start with like this one I did a few years back.
So the question I still need to answer is not if it will run but if I can keep the ecu happy to run full power ???
Old Feb 27, 2013 | 10:46 AM
big_wasa's Avatar
big_wasa
Next plan is to turbo it with an Rs ecu and put it in a rover
Old Feb 27, 2013 | 11:05 AM
XRT_si's Avatar
XRT_si
Answer=yep
Answer=yep
Fair play!
Old Feb 27, 2013 | 12:13 PM
16vzetec's Avatar
16vzetec
This is the kind of answer i was looking for. top work.
The st has different sensors etc than a silvertop so suprised it worked.
What is the sensor on back of engine block near core plugs? Does it talk to ecu or is it just for dash guage?
There seems to be so little info about on the st lump.
Answer=yep http://youtu.be/4UMyy6HXvQ4
http://youtu.be/lLuJS5KiboE
http://youtu.be/Pxq4ks2Us_U
Old Feb 27, 2013 | 12:25 PM
big_wasa's Avatar
big_wasa
Inlet or exhaust side ?
Exhaust side is just the crank sensor and its the same sensor as any other zetec.
The engine has no sensors for the dash other than the low oil pressure warning light as found on any zetec.
Infact there are no sensors for oil pressure or tempretue. I can only assume the ecu simulates these and sends the info to the clocks via the bus.
All the dash info comes from the ecu via can-bus.
The engine will start with very few sensors but in a limp home mode capacity.
Like I say its not if I can get it run but if it will run happy at full power. I will be using every sensor engine wise bar the canister purge so I dont see any problems.
The fuel pump is nothing special.
Old Feb 27, 2013 | 08:43 PM
16vzetec's Avatar
16vzetec
the one below in pic between core plugs, ps note the large port size and smaller seperating piece between each valve hole compared to what the std zetec is like;
also what about the oil cooler? do people still run them? i would like to keep it as i think it must be there because its needed, makes for tight space with the long oil filter though.
i think im going to do a full write up on these engines when im done as it seems that there isnt much info out there on these as of yet!
i want to strip engine completely but not sure how to do it correctly, how does the timing work and what about the thingy on the top of the rocker cover, what does that do and how do i remove it?
Old Feb 28, 2013 | 06:43 PM
big_wasa's Avatar
big_wasa
Ah gotya,
That is the knock sensor and the ecu uses this to listen for detonation.
The vvt works on oil presure. The valve on top of the valve cover is the solenoid that lets the oil into the vvt pulley. The ecu knows where the cam timing is by the cam phase sensor.
I havnt done the belt yet but it looks like its the same as any zetec except you have to hold the vvt pulley with a spanner.
The oil cooler is as much an oil warmer as anything elts. Its designed to get the engine up to tempreture quicker to reduce emissions on warm up.
Having spoken to a few people, most arnt bothering with the extra plumbing. As there are lots of zetec's out there over 200bhp with out one.
Old Feb 28, 2013 | 09:33 PM
16vzetec's Avatar
16vzetec
Ah gotya,
ok thats brilliant knowledge there, im just stripping it and trying all different zetec parts on it to see out of interest will and will not fit.
so far a black top exhaust manifold fits direct, not that youd wanna fit it lol.
got a silvertop 4-2-1 to try on tomorrow.
ideally i wanna fit a silvertop water pump but we'll see........
Old Mar 1, 2013 | 05:55 PM
big_wasa's Avatar
big_wasa
I can save you the time looking at that one.
There is no chance of the silver top water pump crossing over.
Inlet manifold will bolt up but the ports are ~10mm higher on the st so anything like a weber manifold would need porting.
Fly wheels will swap over.
Sumps, its easier to put the silver top on the st than the other way around.
cheers
Old Mar 1, 2013 | 06:09 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
A ST170 KA would be great fun!
A Silvertop goes in without much work, however I'm not sure on a Blacktop.
Old Mar 1, 2013 | 10:18 PM
16vzetec's Avatar
16vzetec
I was thinking ka but its the same problem about what gearbox? Will std ka box fit?
Old Mar 2, 2013 | 06:09 AM
luke19790_3's Avatar
luke19790_3
Turbo box will fit and most ib5 boxes will to
Old Mar 2, 2013 | 08:03 AM
big_wasa's Avatar
big_wasa
If you fit an Ib5 you will need to chop a bit of the sump to move the starter to the front.
Old Mar 5, 2013 | 08:01 PM
16vzetec's Avatar
16vzetec
i just brought my mrs a 1.3 mk3 fiesta and its an injection with a 5 speed box.
i was thinking would the st170 lump fit in that?
will the fuel pump be ok for st170 lump?
i think the engine mount would be pretty simple, the box is a straight fit except the starter and the exhaust wouldnt be a problem, maybe the only issue i can forsee would be the inlet manifold wont fit but i could fit a custom one?!?!?!?
any ideas?
Old Mar 6, 2013 | 07:41 AM
m11rcm's Avatar
m11rcm
A have a ka that has a 1.8 zetec in it only used for track it could be for sale the head gasket gone if any good.
Cheers marc
Old Mar 6, 2013 | 09:06 AM
16vzetec's Avatar
16vzetec
Cheers marc
I need a road legal track car with mot and running. but i never say never if the price is right
Old Jul 20, 2015 | 08:13 PM
pierce1984's Avatar
pierce1984
What flywheel and clutch did you use
JoeyBoyden
Jan 4, 2024 02:36 PM
manuel boeckx
13
Oct 3, 2015 02:29 PM
track.focus'd
Aug 12, 2015 05:53 PM
gordyshreds
20
Aug 10, 2015 02:59 PM
lockie
Jul 31, 2015 10:03 PM
