T3 Stages
Old Feb 13, 2013 | 08:33 PM
fiestaphilwxm's Avatar
fiestaphilwxm
Default T3 Stages
Afternoon All.
Does anyone have any links to an accurate rundown of the differences between the different stage T3 turbos.
Thanks, Phil
Old Feb 15, 2013 | 11:37 AM
fiestaphilwxm
Having a look online and It seems to be the following:
Stage 2 + Stage 3 have a 360degree thrust bearing and a mix of different A/R housings and different trim compressors.
Anybody have any definitive knowledge of what has what?
thanks.
Old Feb 15, 2013 | 06:00 PM
cossieDavedree's Avatar
cossieDavedree
as you say but depends on who manufactures the turbo so it'd be best to phone around
rs turbo t3
std compressor housing ar 42, compressor wheel trim 45 exhaust housing ar 36
stage 1 usually bigger compressor wheel trim 270 bearing.
stage 2 usually bigger compressor wheel trim 360 bearing.
stage 3 usually bigger exhaust housing .48, bigger compressor wheel trim and 360 bearing.
2wd cos t3
std compressor housing ar 42, compressor wheel trim 55, exhaust housing ar 48
stage 1 usually bigger compressor wheel trim 360 bearing.
stage 2 usually bigger compressor wheel t34 trim machined to t3 housing 360 bearing
stage 3 usually bigger exhaust housing .63, t34 compressor wheel and t34 housing and 360 bearing
4x4 cos t3
compressor housing ar 42, compressor wheel trim 60 exhaust housing ar 48
stage 1 360 bearing
stage 2 usually bigger compressor wheel t34 machined to t3 housing, 360 bearing
I recommend cr turbos or universal turbos.
Old Feb 15, 2013 | 07:19 PM
fiestaphilwxm
Thats exactly what I was after. just trying to learn a little more about turbos and specifically the T3.
Thanks pal
Phil.
Old Feb 21, 2013 | 09:44 AM
fiestaphilwxm
Morning all,
Can someone confirm if a Garrett T3 with a 360 Degree Thrust bearing from an Escort RS Turbo (Stage 2?) should have this star shapped 'flinger' plate installed? I was suprised when mine was missing.
The part I am referring to is the part in the middle of the compressor housing on the right of this image:
Thanks, Phil.
Old Feb 25, 2013 | 12:11 PM
fiestaphilwxm
Anyone able to name this part, or even better say whether I need one or not with a 360 bearing?
What does this part even do? I imagine it is there to keep the thrust bearing in place, but is unnecessary with a 360 due to the bolts holding it down?
Thanks again, Phil.
Old Feb 25, 2013 | 06:59 PM
wilky's Avatar
wilky
it's a spring that hold down the bearing and the bearing is standard 270 ,360 are normally bolt down but have seen 2 spring in there ,the oil flinger is the bit with all the holes around out side part of the thrust parts
JK12
33
Apr 26, 2021 12:09 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Mc5506
Oct 5, 2015 09:57 PM
A.t.p
Sep 29, 2015 05:04 PM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
