Jan 23, 2013 | 08:57 PM
  #41
Quote: if you have BOB arms they are no good for the sierra
Why? Which arms are you referring to?
Reply 0
Jan 23, 2013 | 08:59 PM
  #42
Quote: i didnt know this... why is that?... is it cos the late scorpio wings are different or summin?
spose i'll have to buy these too - BOA ones ok? or xr ones? i dont know
The back end is a bit different to the Granada/ sierra set up
As for changing the beam on the 4wd, you can change the arms and be beam and keep the other bits as they will all change over
Even if you have a 7.5 inch diff you can fit it in a 7 inch beam by just chopping a bit if the diff casing off
Reply 0
  #43
whats "they also have a habit of bending the rear beam point up points as they aren't that tough"??? Cheers
Reply 0
Jan 23, 2013 | 09:02 PM
  #44
Quote: Why? Which arms are you referring to?
The arms from engine to mounts the BOA/BOB ones are longer than sierra V6 arms (they can be used but it means modifying stuff)
Reply 0
Jan 23, 2013 | 09:04 PM
  #45
Quote: Sierra v6 arms bud the BOB/BOA arms are slightly longer
545mm centre to centre on a 4i v6 crossmember if anyone wants to measure up their one and see?
Reply 0
  #46
The rear beam is opted through he chassis on a bit of a boxed out section of metal
There is also a big metal plate with 2 more bolts holding that I place to strengthening it all up
But if they get clouted, they can bend as they aren't designed for lateral impacts
Reply 0
Jan 23, 2013 | 09:06 PM
  #47
Quote:
I have some bob pistons n rods if u need them if you don't go for an over bore
This could be a much cheaper option mate seeing as the pistons i'm after are 100-120 each and i need six (and i was gonna mod them too, really going out on a limb to make it unique and lighter)...
and rebore of the block was quoted 40 per hole. i could be lookin at a bag of sand. OUCH...
but it is an ambition of mine to work my engines as much as i can without being dangerous about it... i like to know that mines at least as good if not better than standard stuff if you know what i mean... everything is open to modification in my eyes.
If i get stuck man, i'll get back to you but too much time has been spent waiting on this engine to just put standards back in it... i'd feel like a fool for taking it apart in the first place...
still, thankyou for the offer
Reply 0
Jan 23, 2013 | 09:07 PM
  #48
Quote: The arms from engine to mounts the BOA/BOB ones are longer than sierra V6 arms (they can be used but it means modifying stuff)
But they use the same block and mounts as the 12v so unless it's mounted a little higher I'm not sure why they should be a different length
The 4 pot ones are longer and have a different shape to them
Up until last year I had spares of everything. I then decided my old man would be happier if he didn't have to move them every weekend to a new position like he was playing chess so I binned virtually everything
Reply 0
Jan 23, 2013 | 09:09 PM
  #49
The bob rods are the weakest bit mate
Reply 0
Jan 23, 2013 | 09:10 PM
  #50
Quote: But they use the same block and mounts as the 12v so unless it's mounted a little higher I'm not sure why they should be a different length
That's what I was thinking.
Reply 0
Jan 23, 2013 | 09:13 PM
  #51
My mate converted 4x4 to 2wd and they didn't fit the crossmember he used
Reply 0
Jan 23, 2013 | 09:21 PM
  #52
I just used Granada 24v everything.
Reply 0
  #53
Engine mounting arms.
4x4 V6 arms are short.
BOB and BOA arms are longer and fit the Dohc and cossie 2wd cross member
XR4i arms are different to the others.They are more like 4x4 arms.
Reply 0
Jan 23, 2013 | 09:23 PM
  #54
Wait a sec!!!
excuse my ignorance here but wasnt the BOA and BOB block, basically speaking, a refashioned 2.8 cologne block? (re-stroked with better heads on top)
so therefore shouldnt all the sierra and granada/scorpio v6 engines have the same length mounting arms?
Reply 0
Jan 23, 2013 | 09:24 PM
  #55
my reply was late... doh!
Reply 0
Jan 23, 2013 | 09:30 PM
  #56
Yep that confirms why his didn't work then
Reply 0
Jan 23, 2013 | 09:32 PM
  #57
4i ones
Reply 0
Jan 23, 2013 | 09:34 PM
  #58
i think i just worked it out
the distance between the engine mounting points has to be the same for all the cars (sierras and granadas and scorpios) because they all have the common engine installed.
But as said earlier theres a difference between gearbox input shaft lengths and flywheel thicknesses... suggesting that some of the variants were mounted further forward or backward because of ancilleries and heads etc... could this be - just a varying degree of angle on the arms, making them no wider at all when on the car but, indeed longer when measured in length with a ruler???
or am i talkin out of my gluteous maximus?
Reply 0
Jan 23, 2013 | 09:37 PM
  #59
OK, that picture's quite revealing
Reply 0
Jan 23, 2013 | 09:40 PM
  #60
SO... are the mount bushes completely different for the the 4i and the others?
cos theres a clear difference in width if you put them on a cologne block... so how do they all meet up with the inner wing?
Reply 0
Jan 23, 2013 | 09:41 PM
  #61
I assume the 4x4 has a slightly different wing under the bonnet
Reply 0
Jan 23, 2013 | 09:56 PM
  #62
Engine crossmembers are all different so bolt holes are all slightly out, so you can use BOB/BOA arms but with BOB/BOA engine crossmember, XR4i/XR4x4i arms with XR4i/XR4x4i engine crossmember and so on but you cant mix and match
Reply 0
  #63
Quote: I assume the 4x4 has a slightly different wing under the bonnet
Wings are the same
Reply 0
Jan 23, 2013 | 10:06 PM
  #64
Quote: SO... are the mount bushes completely different for the the 4i and the others?
4i is the same rubber bush as 4x4 cos etc the rest are 2wd like 3door cos and saph
Reply 0
Jan 23, 2013 | 10:38 PM
  #65
Im not too sure what crossmember i have...
- - - i got a 2dohc 2wd saph and im trying to put a BOB in it - - -
i also have the BOB arms that came with the BOB engine and the 2dohc arms that are in the car at the moment.
Reply 0
Jan 23, 2013 | 10:40 PM
  #66
Should work out that the BOB with it's BOB arms fit the 2.0 DOHC 8v cross member
Depends what you read and what you believe
Reply 0
Jan 23, 2013 | 11:02 PM
  #67
Im with ya... cos the bob is used in 2wd format, it should fit the mounting points of a 2wd sierra, not to be confused with 4i or 4x4 formats. job jobbed
Reply 0
Jan 24, 2013 | 06:44 AM
  #68
Quote: My mate converted 4x4 to 2wd and they didn't fit the crossmember he used
The 4wd stuff is totally different so that would explain why nothing fitted
As for the blocks, the 24v is based on the 12 2.9 block
Reply 0
Jan 24, 2013 | 06:07 PM
  #69
dojj
i like the sound of that
Reply 0
Jan 24, 2013 | 06:09 PM
  #70
Quote:
dojj
make it av it... like pushing a kilo of cheese through a letter box
Reply 0
Jan 24, 2013 | 07:43 PM
  #71
the diffs will fit if you remove about half an inch from one of the bolt casing holes, it's not there for anything other than making the diff mounting points fit into the wider beam without the need to modify the diff casing on the smaller diff's
Reply 0
Jan 24, 2013 | 08:52 PM
  #72
can a transit mt75 case be used to convert a 4x4 box?
Reply 0
Jan 25, 2013 | 06:20 AM
  #73
No it has a gear stick fitted to the top of the case unlike the rear remote on the sierra. The 6 speed box has the rear remote but doubtful the internals will fit the 4x4 box front case
Reply 0
Jan 25, 2013 | 06:41 AM
  #74
The internals from the mtx75 boxes as found in some fwd motors also fit
Reply 0
May 20, 2015 | 08:43 PM
  #75
sorry to ask again but...
I need a hybrid Mt75, my type 9 is not good enougth to put power on the road...
i only have a doch mt75 and a 2.9 Scorpio 4X4 mt75... is the 5th gear to short?
Reply 0
Subscribe
