what gearbox will fit focus
Old Jan 8, 2013 | 07:56 PM
si7790's Avatar
si7790
Default what gearbox will fit focus
hi
what gearbox will fit a 2003 ford focus 2.0ltr blacktop zetec
my mate is just trying to do it on cheap i have said just to chuck another ford focus gearbox in there
and do all ford focus st170 gearboxes have 6 gears as he has been told by previous owner that its a st170 gearbox in it but his only has 5 gears
thanks simon
Old Jan 8, 2013 | 08:11 PM
RichieST's Avatar
RichieST
All st170's are 6 speed, they are a getrac box too, pretty bomb proof.
MTX75 is what the 2.0 has I beleive, the rest are IB5.
Old Jan 8, 2013 | 08:48 PM
martysmartie's Avatar
martysmartie
What he ^^ said.
Martin
Old Jan 8, 2013 | 08:58 PM
nevsrevs's Avatar
nevsrevs
Diesel focus runs a mtx75 too.
Old Jan 8, 2013 | 08:59 PM
si7790's Avatar
si7790
would a mtx75 from a mondeo fit if it has a hydrallic clutch
sorry about spelling
thanks for all your replys
Old Jan 8, 2013 | 09:23 PM
martysmartie
Yes, it's exactly the same engine!
Both cars are hydraulic as well.
Martin
Old Jan 8, 2013 | 09:29 PM
si7790's Avatar
si7790
Default hi
thanks thats great thanks for all your help i just wanted to 100% sure i was more worried that the mounting might have been different but thank you everyone
thanks simon
Old Jan 8, 2013 | 09:38 PM
nevsrevs's Avatar
nevsrevs
There are a few little differences like bolt patten on the rear mount and some gear towers are different but nothing you can't get over.
Old Jan 8, 2013 | 09:54 PM
MJ_RST's Avatar
MJ_RST
As above. The mondeo top gearbox mount bolt pattern is different too. It will fit but only with two out of three bolts holding it in.
The gear selector has to be swapped over as well, straight forward enough on these.
And as above, the lower torque link mounts are different. But can be modified to fit.
Old Jan 8, 2013 | 10:01 PM
si7790's Avatar
si7790
Default hi
ok thanks guys for all the info i have another question is the gear box in the 1.8 focus the same as 2.0ltr focus or would one of them fit
Old Jan 9, 2013 | 12:22 PM
martysmartie
No, 1.8 (Excluding Derv) is IB5, and I should think the bell housing etc is different.
Martin
Old Jan 9, 2013 | 01:32 PM
MJ_RST's Avatar
MJ_RST
The 1.8 gearbox is ib5 but will bolt up fine
Just use the correct box for the vehicle
Old Jan 9, 2013 | 02:36 PM
si7790's Avatar
si7790
Default hi
hi got gearbox out only codes i have found is xs4r7f096 and n5lua
Old Jan 9, 2013 | 03:50 PM
nevsrevs's Avatar
nevsrevs
Post a pic
Old Feb 4, 2013 | 05:14 PM
Barry Horn's Avatar
Barry Horn
have you managed to sort this out as i have a 2L black top and im looking for an mtx75 gear box . all the ones ive found are n5lua
and im need to be clear that its the same befor buying a gearbox
regards barry
Old Feb 10, 2013 | 09:00 PM
shalon's Avatar
shalon
I have a 6 speed gearbox and selector if you're interested mate
neil18
Mar 14, 2016 01:08 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
track.focus'd
Aug 12, 2015 05:53 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
Focus Steve
Ford Focus Range
Aug 3, 2015 09:09 PM
