Forf sierra 2.0I sohc
Old Dec 18, 2012 | 12:33 PM
82capri's Avatar
82capri
Default Forf sierra 2.0I sohc
Hi i have just purchased this car and brought as a none runner due to a fuel pump fault. Apoarently :-/
Well their is no spark at any of the plugs. New ht leads. New plugs and still no spark.
I understand many things could be the verdict of this but im really hoping its not a ecu fault. Where should i try next? Ignition coil? Dizzy cap? Dizzy carbon? This car has been sat for 2 years. I would just like help with a few step by step things to check please. Its a D reg 4 speed auto 8v sohc injection
With air con and all the mod cons for the year
Old Dec 18, 2012 | 03:48 PM
doga-ot's Avatar
doga-ot
take dizzy cap and clean check hammer then see if you can borrow a coil also to try and see if yours is faulty.
Old Dec 18, 2012 | 03:50 PM
DixieTheKid's Avatar
DixieTheKid
Pick-up P100 Power!
Yep dizzy or coil. I have both a lot of spares if you need any. PM me.
Old Dec 19, 2012 | 12:08 PM
martysmartie's Avatar
martysmartie
First check the coil has power reaching it, does the fuel pump prime? It may well be that input to the ECU, i.e. CPS.
Martin
Old Dec 19, 2012 | 12:50 PM
82capri's Avatar
82capri
Hi guys thanks for the advice will get checking today, The pump does not prime at all no, is their a way to check the crank position sensor?
I will go down the garage with a charged up battery today
Old Dec 20, 2012 | 12:06 PM
martysmartie
You can measure the voltage at the pins in the ECU, although I am not sure which ones this would be with your ECU, I have a manual that does though if you get stuck
Martin
chowfornow
14
Jan 5, 2019 09:01 PM
Nov 1, 2015 06:53 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
Fil
Sep 30, 2015 12:08 PM
SMILER258
Sep 28, 2015 09:04 AM
