Focus st clutch pedal?
Old Dec 3, 2012 | 05:00 PM
locum8's Avatar
locum8
Default Focus st clutch pedal?
Hi , I just bought a focus st about 4 weeks ago and it has recently developed a problem with the clutch pedal.
Every morning I go out the clutch pedal is sitting about 1/4 of the way down and when I press it it returns to this position unless I physically pull it back to it's correct position. Also the bitting point is ok when cold but as the car heats up it gets really high almost right at the top.
Now I have seen the same problem on other threads/forums but no one seems to come up with a definite answer as to what is causing it, like some people say it's the master cylinder, some say the pedal box and others say it's the slave cylinder?
Any help would be appreciated.
Also The car is a "59" plate with 16k miles.
Thanks!
Old Dec 3, 2012 | 06:35 PM
D11AKS's Avatar
D11AKS
Thanks!
It's the spring in the pedal box goes week , would need to remove the pedal box to change the spring
It's the only cure I have heard of that works mine does the same but not bothered me
Once I have used the pedal once it's fine for the rest of the day
Old Dec 3, 2012 | 07:06 PM
locum8's Avatar
locum8
Hi, do you know what spring it is?
Is it the big one or the small one with the plastic bush inside?
Old Dec 3, 2012 | 07:14 PM
BRAM's Avatar
BRAM
It sounds to me that it's either master cylinder or slave, i can't see how a spring on the pedal would cause a high bitting point.
yatta
May 21, 2016 10:31 PM
talon1
Sep 15, 2015 10:27 AM
Flateric_2002
Sep 15, 2015 08:41 AM
focus2351
Sep 9, 2015 09:33 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
