turbo glowing red hot
Old Apr 25, 2004 | 11:16 PM
oriont's Avatar
oriont
Default turbo glowing red hot
after a quick 20 minute thrash to work tonite when i stopped my car got very hot very quick, had a look under the bonnect and turbo was glowing red hot, never seen or noticed this before and woundered if it was ok or not??
thanks
oriont
Old Apr 25, 2004 | 11:18 PM
timing out or overfuelling! get it sorted.
Old Apr 26, 2004 | 03:43 AM
Bit like that maybe?
Old Apr 26, 2004 | 04:16 AM
oriont's Avatar
oriont
not quite that bad but yes.
is it really something i should be very worried about?
i wouldnt of thought it was either of those problems as it was only mapped by Stu in December.
ive got enough things on the car to do as it is.
thanks
oriont
Old Apr 26, 2004 | 04:21 AM
Nah, most turbos are designed to cope with that amount of heat. If your running a rich mixture you will get it.
Old Apr 26, 2004 | 06:27 AM
dave green's Avatar
dave green
I get it most of the time its quite normal.
Old Apr 26, 2004 | 06:33 AM
oriont's Avatar
oriont
thanks guys
i was getting worried
thanks
oriont
Old Apr 27, 2004 | 08:55 PM
rwd106's Avatar
rwd106
the joys of having the engine behind ur head means i get to c this site as soon as iut gets a bit dark, by time im on a12 2-3 mins of 80mph and all four branches glow, it looks great, ill try get sum vids!!
Old Apr 28, 2004 | 08:08 AM
JesseT's Avatar
JesseT
A better flowing turbine wheel and housing helps a lot.
Old Apr 29, 2004 | 07:26 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
This happens to me quite a bit as well, and ive never suffered any problems from it
Old Apr 29, 2004 | 04:06 PM
oriont's Avatar
oriont
thanks guys
oriont
Old May 5, 2004 | 07:15 AM
Oz_RS500's Avatar
Oz_RS500
you will find that the turbine hosuing will get red hot if you're pushing it at high boost for a whaile, also if the engine tune is out (i.e., retarded ignition timing & rich fuel mixtures), the same will happen.
it shouldn't be a problem, but make sure u give the car/engine a cool down lap before switching it off.
Old May 5, 2004 | 12:53 PM
MadMac's Avatar
MadMac
Ahh they do it all the time, don't worry!
Matt Baxter
Sep 16, 2015 08:30 PM
mrknifey
Aug 30, 2015 11:48 AM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
Bailes1992
Aug 16, 2015 07:14 PM
muz
Aug 16, 2015 12:57 PM
