TDC sensor question (saph 2wd)
Old Mar 8, 2005 | 05:05 PM
Mechanic_Wedgie's Avatar
Mechanic_Wedgie
Default TDC sensor question (saph 2wd)
Can a missfire caused by a faulty/old TDC sensor.
A while ago i had some simaler problem and it turned out te be the phase sensor in the distributer.
Now i got a same sort of problem.
And the gap for the TDC sensor is that +- 1mm??
Cheers for the answers,
Ruud
Old Mar 8, 2005 | 08:38 PM
Stu @ M Developments's Avatar
PassionFords Creator
Hi,
A TDC sensor can cause a missfire yes.
The gap is 0.6 - 1.0mm I personally use 0.8mm.
Old Mar 8, 2005 | 08:47 PM
Mechanic_Wedgie
Thnx for the answer
Old Mar 12, 2005 | 03:37 PM
Mechanic_Wedgie
Replaced today the TDC sensor, no more misfire
mint_s2
Sep 2, 2015 08:58 AM
FlashRS
13
Aug 31, 2015 06:02 PM
Anutternutter
24
Aug 31, 2015 01:24 PM
ray barker
Aug 7, 2015 09:00 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
