ICV for ALS
Old Oct 28, 2012 | 11:55 AM
s9ott's Avatar
s9ott
s9ott
Default ICV for ALS
Running MSD ALS on my 3dr sierra cosworth, and the standard ICV keeps fecking up, whats the best replacement type to go for?
Old Oct 28, 2012 | 12:03 PM
JamesH's Avatar
JamesH
In what way is it fucking up?
Old Oct 29, 2012 | 03:07 AM
s9ott's Avatar
s9ott
s9ott
Some times when I do the electrical checks on it, it works other days it does not, so lost the confidence in it and would like to change it out for a new better model, if there is such a thing out there, I know it might be something else that’s wrong but starting with the ICV 1st.
Scott
Old Oct 29, 2012 | 07:11 AM
KSA-Cossie's Avatar
KSA-Cossie
I'd check the wiring right first.
Old Oct 29, 2012 | 09:50 AM
s9ott's Avatar
s9ott
s9ott
I can't find anything wrong with the wiring, so think its time to change the 26 year old ICV with something better.
does no one know of any good uprated go faster ICV !!!
cheers
Old Oct 30, 2012 | 02:05 PM
martysmartie's Avatar
martysmartie
An ISCV is an ISCV lol!
Be wary of the aftermarket ones, they are not a fit and forget item, they need setting up, and I found the wrong spring ratings were wrong as well.
Martin
Old Oct 31, 2012 | 05:16 AM
s9ott's Avatar
s9ott
s9ott
I starting to think i should just buy a new one from Ford, and drill out the ports again for the ALS to work better.
Old Oct 31, 2012 | 07:14 AM
KSA-Cossie's Avatar
KSA-Cossie
Did you drill out the throttle body too ?
Old Oct 31, 2012 | 07:39 AM
Stu @ M Developments's Avatar
PassionFords Creator
Can you elaborate on what the actual preoblem is that your experiencing? We have plenty of ALS valves available from mild, to comedy flow, but first you need to find out whats wrong with what you have.
Old Nov 1, 2012 | 01:47 AM
s9ott's Avatar
s9ott
s9ott
Stu
I'm starting to think it’s the spring that’s just lost its springiness, it looks as if it just sticks now and again, it works for a little while after I strip and clean it.
Unfortunately the cars sitting waiting on me picking a new turbo so can’t test it further.
If you’re bored and have time to look at my posting about what Turbo to buy for the car I would be very grateful.
https://passionford.com/forum/technical-help-q-and-a/440038-what-turbo.html
As once its all back together your garage has the fun of live mapping it, and I guess if you have ICV in stores you can solve 2 birds with one stone.
Thanks
Scott
Old Nov 1, 2012 | 07:16 AM
Rollinz's Avatar
Rollinz
Sorry for hijacking this thread but this question may also help you lol,
Ive just bought a grp n escort recently,
I was wondering if the ecu actually uses the same output for iscv as it does for als?? Or is it re pinned when done??
Reason i ask is i want to know if it is possible to put the iscv back to doing its job, then fit a bosch iscv with 15mm input/ouput and just join it into boost pipe and have inlet modded with a 15mm hole to join direct into?
If that makes sense lol
Stu, also how much boost is possible when running als on a t34 with restrictor (group N car)
Tony Turbo
50
Sep 19, 2005 07:46 PM
Azrael
Jun 26, 2005 02:22 PM
Fastmaul
32
Feb 7, 2005 11:43 AM
Stavros
Dec 23, 2004 07:14 PM
