zetec turbo silvertop needed and a few questions
turbovh
Trying to sort out my 2.0zetec turbo fiesta damagedbabglandbon piston 3 to detonation andnpinking were guessing from dismantling it the crank is not looking to good so I want to replace the bottom end to avoid any further issues my head us just rebuilt and ported and polished so I want to keep it does the silvertop head fit a black top block or willing need a silvertop bottom end I am assuming I will
It would be ideal if anyone has a silvertop block or any ideas thanks
does the silvertop head mate to a newer blacktop bottom end?
anyone running zetec turbo on ofab?
anyone else having det problems?
when my afr's were being checked was running slightly lean throuout its on cossie greens
turbovh
was running a msd chip off a zetec turbo i was told anyway, by te fella i bought the loom and ecu off, what sort of wok is involved with mating silvertop head with blacktop head, i am planning to go megasquirt ms2 anyway have managed to source a kit for around the 400 mark, loom, ecu etc what is the best chip to use on a zetec turbo? i have come across a few by a few different companies any recomendations?
turbovh
Cameron
14
09-08-2015 06:28 AM
