fuel pump prob xr2i ztrbo
Old Sep 1, 2012 | 11:44 AM
HirenRS's Avatar
HirenRS
turbovh
Default fuel pump prob xr2i ztrbo
got too work fine then pump would not turn on now only runs if i give it a positive from battery pump doesnt prime either any ideas pls ....
Old Sep 1, 2012 | 06:07 PM
xrmalin's Avatar
xrmalin
Have a check of the inertia switch down in the passenger foot well the one in my old 2i packed up all of a sudden with no warning.
Old Sep 1, 2012 | 07:07 PM
JOHNDQ's Avatar
JOHNDQ
If not the above check the relay
Old Sep 1, 2012 | 09:55 PM
HirenRS's Avatar
HirenRS
turbovh
turned back on by itself weird problem this one also had a bit of trouble with superchip today where is this intertia switch exactly had a look round couldnt see it what does it look like might check all wiring and the realy is not present has been bridged in past
Old Sep 1, 2012 | 10:12 PM
JOHNDQ's Avatar
JOHNDQ
In that case i would say the wiring is f**ked, the pump must be running non stop with ignition
Old Sep 2, 2012 | 11:58 AM
HirenRS's Avatar
HirenRS
turbovh
am i correct in saying that if the relay terminals have been bridged it wouldnt prime?...i have owned the car for 5 years its never primed, i think the pump could be running a live from ignition as apposed the relay will have a look through it today....its intermittent pump turns off when it wants and does not respond at all
Old Sep 2, 2012 | 05:12 PM
xrmalin's Avatar
xrmalin
The inertia switch should be in a little flap behind the kick panel in the front passenger side footwell. Its quiet a big black box with if my memory serves me right a white plunger so it should stand out a fair bit down there.
I'd deffinatly have a look at your fuse box area if the relay isn't there some ones played funny buggers with it some where along the line.
If you take the kick trim off the drivers side you should be able to trace/follow where the fuel pump wires go to and see what the crack is with them.
Old Sep 2, 2012 | 05:35 PM
HirenRS's Avatar
HirenRS
turbovh
found it and checked all wiring connections seem, found inertia switch and the white plunger was out i clicked it in it did not return allowing me to click it again, does this means it is now okay to run a relay and it should prime now i think
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
155lee
Oct 24, 2015 11:11 AM
15
Oct 7, 2015 03:43 PM
tib2220
Sep 14, 2015 12:33 PM
