ST170 issue, needing ideas!
Old Aug 28, 2012 | 12:21 PM
telf's Avatar
telf
Default ST170 issue, needing ideas!
Hi all,
I have posted the below in a thread in the Focus ST section but had no joy as yet so I had another look around and have found this section of the site.
Hope you don't mind it getting posted again but I could really do with some ideas as I am out of them just now
Originally Posted by telf
Hi all,
1st post on the forum but I've been a lurker for a while!
As per the title it's an ST170 on a 54 plate with around 60k on clock.
Problem is a bit hard to describe but I'll give it a shot.
If you drive the car very quietly (gear change approx 2k) all seems not to bad just a bit jerky but if you press on the accelerator a bit harder the car just dies basically and you need to coast to a stop. You can't rev it as pressing the pedal has no effect what so ever. You need to let the car sit for 10-15mins before it even considers restarting then it will idle but not rev until it feels like it and you can set off again but slowly until it decides to cut out again.....so repeat the above! this is fairly annoying so its parked up!
I have taken the imrc box off and change the tp121 transistor and put it back together (the were no fault codes relating to this but an auto electrician said it wasn't working correctly and causing the issue) the imrc works fine, when started it moves to the closed position and when about 5.5k and above it opens. I have also tried running the car with this disconnected and it made no difference.
The battery light seems to be coming when higher up the rev range then will stay on for a bit a low revs and the dash lights dim and brighten as they please. the voltage across the battery is approx 14V when idling but I haven't checked its output when up the rev range yet.
Any ideas guys?!
Any specialist garages about or recommended ones?
Anything else to check?
The car is standard apart from a k&n panel filter which has been on the car for 2 years.
David
Old Aug 29, 2012 | 04:35 PM
telf's Avatar
telf
anyone?!
Old Aug 30, 2012 | 09:48 PM
AstoN_B's Avatar
AstoN_B
An eye for detail...
That is an odd one, sounds almost like a mixture of things.
History on the car? Did you buy it like that or has it been fine until a certain time?
Odd that no codes are showing too...
Old Aug 30, 2012 | 09:58 PM
telf's Avatar
telf
Had the car 3 or 4 years now and to be fair to it it hasn't missed a beat until 3 and a bit weeks ago.
Plugged code reader in again tonight and still nothing that's gonna help me out!
Think I'll just bite the bullet and buy a new imrc unit to rule it out for definite and then sell it on if it makes no difference and hopefully not be too much out of pocket!
Palethorpe01
15
Aug 18, 2015 06:09 AM
ekjim
Aug 17, 2015 08:57 PM
track.focus'd
Aug 12, 2015 05:53 PM
col93saphcos
Aug 7, 2015 03:21 PM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
