Focus tddi - drop in power - help!!
Old Aug 26, 2012 | 06:10 PM
Dawson Bullock's Avatar
Dawson Bullock
Default Focus tddi - drop in power - help!!
Hi, My 2002 tddi is suffering from a random drop in power. If I turn engine off then restart it's ok for a while. There is no smoke, no flashing glow plug light, no strange noises. It runs and drives reasonable, just as if there is no turbo.
I've had this before on another focus and was just an air leak on the maf sensor pipe.
I've checked all my pipes on the intercooler circuit, can't find anything.
I have a 'donor' car for spares in the garden so I've swapped the maf sensor & the EGR solenoid & intercooler sensor. Still the same.
Any suggestions?
Regards, Dawson
Old Aug 27, 2012 | 01:35 PM
Dawson Bullock
I've just blanked 'egr' valve off to see if it makes any difference.
I'll try to follow this through to the end incase it helps anyone else as it looks like I'm on my own!
Old Aug 28, 2012 | 09:07 PM
Dawson Bullock
Wife's been driving it today, says it's ok, but I'll give it a few days to make sure.
If it's cured I'm not sure whether to leave it blanked, or remove & clean.
It's a good job I found this forum; I've managed to help & advise myself loads.
Old Aug 29, 2012 | 09:15 PM
Dawson Bullock
Good luck pal, hope it goes ok. If not give me a shout.
Old Aug 29, 2012 | 09:18 PM
Dawson Bullock
I'm back. No, looks like the egr is probably ok.
My next move is.. swap a set of injectors 'cos I have a spare. If no better then I will take off the cat and see if blocked.
Old Aug 29, 2012 | 09:35 PM
botters's Avatar
botters
competant bodger
lol what a thread!
it may well just be the egr as they do cause your above symptoms
Old Aug 29, 2012 | 09:36 PM
botters's Avatar
botters
competant bodger
are they electronic injectors on yours? if so the injectors will need programming to your ecu
Old Aug 30, 2012 | 06:58 AM
Dawson Bullock
Hi there, I've blanked the egr so surely that has eliminated egr?
Regarding the injectors there's no wires attached so no programming required I assume. The car is a 2002 tddi, not equipped with MIL light or other engine management lights if that helps.
Suppose I'll have to just swap and see!!
Cheers, Dawson
Old Aug 30, 2012 | 08:24 AM
rsfido_1989's Avatar
rsfido_1989
Is the turbo kicking in my tddi fiesta wasn't,
I had the egr, inlet and turbo off. As above they all needed cleaning.
The turbo had oil in the actuator and 'hydrolocked', leaving the pipes of and a pair of grips I pumped it. Squirted oil out and then i made a pressure tester, 2 bar open fully then 1.5 bar afte 5 minutes.
Old Aug 30, 2012 | 08:30 AM
Dawson Bullock
It drives normal, then randomly it loses power and FEELS like no turbo. Then if i switch off ignition and restart all is ok again. Some days it's faultless.
Don't forget, I've blanked the EGR now and it's no different, so It's not the EGR.
Old Aug 30, 2012 | 04:53 PM
rsfido_1989
Clean the inlet, clean the vacume hoses to the actuator, could be crap making it loose boost, move the actuator arm and grease the moving parts. All depends how dirty you want to get.
Old Aug 30, 2012 | 08:51 PM
Dawson Bullock
Not as dirty as the wife, lol. Yes that sounds good advice mate. Will i be able to do this without removing turbo?
Old Aug 30, 2012 | 09:08 PM
rsfido_1989
Not sure on the focus but I did mine by undoing the exhaust and removing the whole turbo/manifold/downpipe. It's a good days work to strip inlet/egr and turbo, strip clean grease and refit. If you want to test the turbo message me and I'll tell you how I did mine.
Old Aug 30, 2012 | 09:23 PM
Dawson Bullock
Ok, gonna strip it Saturday. Cheers.
Old Aug 31, 2012 | 11:06 AM
Dawson Bullock
I've just been reading another thread regarding blanking the EGR which I have done, but I didn't block off the vaccuum pipes that go to egr solonoid valve and re route the one from the valve itself to the left port on the solonoid as stated in the thread. I best try this first.
Old Sep 4, 2012 | 05:26 PM
Dawson Bullock
Anyone following this thread please bear with me, I WILL update when I get to bottom of problem. Thanks.
Old Sep 23, 2012 | 08:30 PM
Dawson Bullock
An update for everyone....
So far I have changed:
1, Diesel filter, & injectors
2, Map sensor
3, egr solenoid
4, Inter-cooler sensor and Air box sensor,
5, Accelerator pedal,
6, Turbo
7, Blanked egr valve
I've checked all vacuum hoses there are no air leaks and intercooler is not blocked.
Turbo was changed today, but the old one looked fine, not clogged, spun freely.
Just one thing - I took out the flywheel sensor it was reading approx 400 ohms. Is this value correct?
I'm beginning to think it's electrical, maybe a broken wire as the fault disappears when ignition is turned off then back on.
Old Sep 25, 2012 | 07:19 AM
Dawson Bullock
The flywheel sensor is correct at 400 ohms I have found out. The saga continues.....
Old Sep 25, 2012 | 03:02 PM
black_jack's Avatar
black_jack
Black Jack
Hi - even though you've blanked the EGR (its a solid plate? - no holes to let the gasses through?) the inlet manifold could still be "coked up" from 10 years of carbon/ mock + the breather muck adds to this forming an oily sludge
so your engine may be getting "choked" from this carbon/ sludge
an older engine may produce a lot of muck from the breather - you may have to clean out the intercooler too - and fit a catch tank to the breather outlet
You don't mention whether you have changed your air filter/ when was it last changed - again - this can choke/ restrict your engine
the injectors on a TDDI are mechanical and do not need to be coded/ recoded - they have a reputation for being more reliable/ doing higher milages than electronic injectors (TDCIs)
does your car have a fixed vane turbo with wastegate and actuator or a variable vane turbo?, (the variable vanes can coke up/ sieze)
the turbo relies on energy from the engine, if the engine is not producing the heat/ pressure energy to "feed" the turbo, (eg - if it is choked or has a fault) the turbo will not boost up, causing a "knock-on effect"
A fresh air filter is under a tenner and cleaning out the inlet manifold should be cheap too - always best to do the cheaper things 1st, especially if they are "sevice" items too (or should be)
Old Sep 25, 2012 | 09:11 PM
Dawson Bullock
Hi black jack, thanks for the comments. The air filter is fine. My turbo must be fixed vane as it has a waste-gate. Don't forget that all these faults disappear when the ignition is turned off then back on.
Surely if the inlet manifold is so badly clogged the fault would be there all the time.
I can replicate the fault by disconnecting the air temp sensor on the inter cooler. I am going to check the wiring for any breaks. Also next time it faults I'm gonna lift the bonnet and check for +5v on these 2 wires which it should read when working. If no volts then possibly a fault in the wiring.
Old Sep 25, 2012 | 09:37 PM
MAD Ade's Avatar
MAD Ade
There is a tracable fault somewhere as the management is switching to limp home mode. Get it on a diagnostic machine, will tell you the fault pretty much straight away.
Old Sep 25, 2012 | 09:47 PM
Dawson Bullock
The on board diagnostics (pressing the milometer button) says 'dtc - none). Would it still show a code on a proper machine?
Old Sep 25, 2012 | 11:35 PM
black_jack's Avatar
black_jack
Black Jack
I think the on board diagnostics could be very basic, and i concur with ade that its probably a (code reader) tracable fault if it is going into limp (home) mode
you can buy a code reader online that will do 99% of what a garage code reader does, and you can use it again and again without additional cost, it is about 20-25 quid, (eg- an F-super) , it requires a laptop, you can also get stand alone/ handheld ones too- a worthwhine investment for you. IMO
it can also give you other information that may be useful
Previously i mis- interpreted your fault/s (oops)
Old Sep 27, 2012 | 07:49 AM
Dawson Bullock
Yeah I get what you are saying mate, but there is no 'limp mode' on my car as it's the older version.
I've got a code reader - Autel Ms509 but it won't work on the Focus (just works on all my mate's)!!
Might have to bite the bullet and take her in.
Old Oct 1, 2012 | 07:28 PM
Dawson Bullock
I've had the car into a garage today to have the fault codes read.
However, £20 later I'm informed there is no fault codes registering.
Old Oct 1, 2012 | 08:35 PM
Cossy Mike's Avatar
Cossy Mike
Mines a 2004 Tdci 115ps and mine does this.........no idea what to do.
However the ignition off and back does'nt do anything it still stays limp.
When I put my foot down I don't know if it's going to boot off or be flat.
No smoke or anything on mine either
Will be watching this thread closely as I would like it fixed before winter
Old Oct 10, 2012 | 03:41 PM
Dawson Bullock
Bear with me everyone, it's doing me noggin in now lol.
I've changed the Cylinder Head Temp Sensor (around £14 from Ford). Still no different.
Old Oct 28, 2012 | 06:22 PM
samiharju's Avatar
samiharju
Hello from Finland.
I have same kind of problem with -99 TCI Focus. After start, everything is OK for about 0,5-5km, but after that engine loses power, runs like non-turbo engine. When i turn ignition on/off on-the-fly, all will be ok for a while, until it does the same trick again.
When I bought this car 2 weeks ago, it had MAP sensor pressure pipe broken and it didn´t boost at all -> fixed immediately.
Codes readed with AutoCom:
P1564 Pump requesting reduced fueling
P0167 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
Things done so far:
-Injection pump´s ECU has been fixed for about 50000km ago.
-New fuel & air filter
-No visible fuel or air leaks
-Wiring looks to be ok
-EGR manually blocked
-Tried another MAP sensor from 100% working car
-Tried another actuator control valve from 100% working car (I don´t know what is it called, near the map sensor fastened to firewall, 3 hoses and electric socket goes in it)
-Manifold air temp sensors cleaned (both 2), I will test them tomorrow when car is in +20c temp.
Car does still the same after all that...
Old Oct 28, 2012 | 06:53 PM
Cossy Mike's Avatar
Cossy Mike
Quick update from mine - It's fixed itself! every now and then it'll be a bit sluggish and drop off the power.
Really has the be the EGR valve on mine, does anyone have an idea how to clean it up on the car??
Old Oct 29, 2012 | 05:51 PM
Dawson Bullock
Okay, I've finally sorted mine. I replaced the manifold to egr vacuum pipe!!
Now then... After checking all pipework several times and finding no splits or holes of any kind I replaced this for the pure and simple reason that I had some similar pipe in the garage laying around.
Even now I still can't see anything wrong with the original (I've yet to pressure it up), but there is absolutely no visible fault with this pipe.
The car has been fine for around 8 days now, really can't believe it. You can buy this pipe / metre length on ebay for £1.25 delivered so it's worth eliminating for ther price.
Hope this helps someone.
Daws
Old Oct 29, 2012 | 06:02 PM
Dawson Bullock
Yes you can, might depend on how bad it is though.
1, Remove rubber elbow section pipe on egr. Inspect with mirror/torch - you can see the valve and how bad it is. If it's chokka block then maybe best to remove, but mine wasn't.
2, Remove bottom metal 'concertina' pipe (2 small studs 10mm I think).
3, You can then move pipe to one side.
4, Using a 1/4 drive 'T' bar and extension with a 10mm socket on (or similar - it's just a matter of finding something that fits and you can move easily) you can push this up from under the valve where the concertina pipe was and physically move the valve up and down to free it off. Use EGR spray and a tooth brush, and then keep working it up and down.
Again, it's up to you to determine how badly coked up it is but I wouldn't remove manifold unless absolutely necessary.
Old Aug 27, 2024 | 03:45 PM
DenisRPT's Avatar
DenisRPT
Default Sorry for reoppening the thread , but I have the same problem
Originally Posted by samiharju
Hello from Finland.
Things done so far:
Did you find the problem ? I have the same errors in autocom, I changed every sensor and boost pipe , and it won t work . What was the cause on yours ?
Old Aug 28, 2024 | 09:40 AM
Dawson Bullock
Hi, Yes I did!. I replaced the inlet manifold which has the round diaphragm on top of it. I prised the old one open to have a nosey inside and there was a tiny split in it.
Hope this helps you.
Dawson
Old Aug 16, 2025 | 10:53 PM
gio00c's Avatar
gio00c
Dawson
Hey mate is the car still working properly? I got the same problem you had, have you replaced the manifold to egr vacuum pipe or the entire inlet manifold? My car is driving me crazy, works good for the first 5 minutes then it's like the turbo is dead.
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
gavt123
Sep 5, 2015 10:03 AM
hopper350
Sep 4, 2015 12:53 AM
Sep 3, 2015 10:49 AM
