Problematic s1 4 yr old problem
Old Apr 23, 2004 | 02:06 PM
Default Problematic s1 4 yr old problem
I've had a mint s1 for 4 years and after 2 engines 4 boxes 3 brains 4 air flow meters, fuel pumps, throttle sensors, coils filters plugs and anything else that can be changed i still have same problem, pulling slowly and cutting out at 3000 or 4000 rpms, rev counter drops to 0 and no more go. Lift off accelerator dump valve goes off and car runs fine again. its currently got a 242bhp power engineering engine and chip which was bought from a friend. it still doesnt go anywhere. im thinkin of fiesta efi management cos i got a need for speed (and CHATTER) could you possibly help me before i get a nova urgh!!!!!! any help would be appreciated
Old Apr 23, 2004 | 02:23 PM
John Laverick's Avatar
John Laverick
Have you got descent boost hoses on there, sounds like the hoses are collapsing under boost (especially if its big boost), this causes exactly the symptons you describe. Also has the chip got sufficient boost capacity for the amount of boost you trying to run, as it could be hitting a boost limiter (even if the cars chipped).
I would recommend taking it to a decent tuner, i'm sure they could find the problem innotime at all
Old Apr 23, 2004 | 02:41 PM
Got new samcos sorry try again
Old Apr 23, 2004 | 02:55 PM
John Laverick
What about the chip??
What boost you running? What Chip Is it?
Have you had it at a tuner??
Old Apr 23, 2004 | 02:57 PM
its been to several tuners pts places like that. its a power engineering unlimited boost chip ive tried 2 other chipped brains 1 standard still same it ran 18 psi no worries in previous car mine has run shit on both engines????
Old Apr 23, 2004 | 03:14 PM
John Laverick
hmm don't know what to suggest then if you've changed everything. I'm very surprised a reputable tuning company can't find the problem though!! Try a post in the main forum,you might get some more response?
Old Apr 24, 2004 | 05:51 AM
sounds daft but have you cleaned your air filter recently mine was doing similar things took the filter off quick run round the block problem gone. takes 2 minutes to do and you will kick your self if it works ...... i did hopurs of dicking about to find that
Old Apr 24, 2004 | 10:24 AM
cossieant's Avatar
cossieant
sounds really daft have you tried blockin the dump valve off???
my s2 did this replaced everything but in the end it was just the dumpers!!!
Old Apr 24, 2004 | 11:28 AM
DazC's Avatar
DazC
Possibly charge air temp sensor...
With the rev counter dropping to 0 it is a sure sign that the ECU is cutting the spark for one reason or another.....it's going to be down to either an ECU fault, wiring or sensors....
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
